start problems
Old Feb 5, 2002 | 07:25 PM
veink's Avatar
start problems
IM having some real problems getting my tII to start when it is cold. The connector to the aws solenoid has a broken wire. Does any one know how to fix this problem or where to get a good used one.
thanks
Old Feb 5, 2002 | 08:22 PM
akageals's Avatar
No, but......I don't think that should affect your cold start. I have mine completey removed and my car starts immediately when cold. That thing is used to heat up the cats quickly for Fed. emissions standards. You might look for an unplugged air intake temp. sensor or maybe a vac. leak. Do you have any other symptoms? I have an air intake temp. sensor and water thermo sensor if you end up needing either of those.
Todd
Old Feb 5, 2002 | 08:23 PM
akageals's Avatar
One more thing. I have an AWS for 87 - 88 TII off my car that was known to work when removed.
Todd
Old Feb 5, 2002 | 09:41 PM
veink's Avatar
more symptoms.
well while I was trying to start it the other day, it was trying to like normal, starts for a second and then dies, but after a little bit of this it gave up trying and doesnt sound like its even firing now, ive got a new set of plugs, but i wasnt going to put them in until after I tried the atf thing. For a few days prior to the above situation, the car would start eventually but would die if i didnt hold down the gas until it was fully warm. after it warms up, it runs fine. while im cranking it though, it wil die immediatly if i touch the gas until it geets to a cartain temp.
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
