Idling problem
Old Feb 26, 2006 | 02:08 PM
Keegan's Avatar
Idling problem
I can't figure out why my 88 2nd gen RX7, non-turbo, is not idling properly. We removed the emissions and now it runs really bad at 3000 and lower, idles at 2000 and dies. The exhaust is really, really hot. Thanks for all your help.
Old Feb 26, 2006 | 02:17 PM
Sideways7's Avatar
Is it very uneven and bouncing when it does idle? If so, it sounds like you have a vac leak you could suck a cat through. Search around for methods of finding vac leaks. After that I'd check the TPS adjustment and idle speed screw on top of the TB.
Old Feb 26, 2006 | 02:24 PM
Keegan's Avatar
I also have a broken injector on the primary fuel rail.
Old Feb 26, 2006 | 03:17 PM
MattB's Avatar
MattB
well there is your problem....injectors cause BIG vac leaks...replace it...and replace the o-rings and grommets too.
Old Feb 26, 2006 | 06:08 PM
Keegan's Avatar
no the part that is in the intake that thing that go's around that needle
Old Feb 26, 2006 | 07:14 PM
Keegan's Avatar
does someone know y my exhaust is so hot
Old Feb 27, 2006 | 03:46 PM
Chuck's Avatar
RX7 exhausts are seriously hot anyway, but if you're running too lean (like you would with a vacuum leak) it will be worse. When verifying vacuum leaks, make sure you check the UIM and LIM gaskets. If they are worn out or brittle and torn they will cause major vacuum leaks that will definately screw up idle.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
ZacMan
Sep 19, 2015 09:20 PM
firzen
Sep 15, 2015 12:04 PM
rx7shirley
Sep 2, 2015 02:11 PM
