What do i need to beat a GSR?
Old Feb 5, 2002 | 02:27 PM
nitrouspeed2's Avatar
ok guys, i just bought a 91 gtu, What type of mods do i need to beat a gsr w/intake, cat-back?
also, can i beat a civic ex with headers, intake, custom exhaust?
with me stock?
Thanks,
Jason
Also what would be my best bet for exhaust? custom?
Old Feb 5, 2002 | 02:34 PM
pd_day's Avatar
Spoolin'
how much money do you have that you can spend?
no $ = strip car until bare metal, with 1/8 tank of gas and you being 140lbs. Punched cats and muffler hollow.
$ = get pipe to replace cats
$$ = get header + mid pipe/used drag radials for better launch
$$$ = get header + presilencer + cone intake
$$$$ = get front section of exhaust + cat back
$$$$$ = get true dual exhaust
Agent_D's Avatar
rawr
The GS-R, you would need equal mods to stay with/beat it, unless the guy cant drive, the civic ex you should have no problem with stock, if your ports and VDI is working correctly.
exhaust, either go with a Mazdatrix true dual if you want to shell out 1400 bucks, or you can go ahead and build a custom one yourself.
Old Feb 5, 2002 | 02:36 PM
sublimeracing's Avatar
Hey man whats up? I have a 88T2 that smokes the hell out of intega's but b4 I got it I had an 89 celica gts that would beat gsr's. The most important things you'll need is intake,exhaust(get rid of the cats [if you don't have to pass emissions],and headers. Make sure your compression is good to. You should be able to hang if not take him in a well running 7. Front whheel drives are hard to launch unless your a really good driver...(which he probably isn't) As for the civic you should be able to take him stock if your motors running well. Good luck
Old Feb 5, 2002 | 02:46 PM
ROSHX7's Avatar
A GSR with Catback and Intake most likely has got another 15hp added to it, resulting in 185hp. I've raced tons of them around here, drags, highway, you name it. Its not that slow, its possible if the guy is a good driver, that its a low 15s car...so try to aim for low 15s or lower with your ride if you want any chance to beat it!
Old Feb 5, 2002 | 02:49 PM
Agent_D's Avatar
rawr
yea, IF he is a good driver he call pull off low 15's, not being a smart ***, but MOST honda/acura guys dont know how to launch there car, ive seen it around here, ive taught a few of them how to launch better, but they dont listen, they think spinning their tires is better then a slightly squealing start with more traction, but oh well
MikeL's Avatar
What's a GSR?
Old Feb 5, 2002 | 02:57 PM
Ryde _Or_Die's Avatar
Originally posted by MikeL
What's a GSR?
Acura Integra GS-R
Old Feb 5, 2002 | 03:09 PM
MikeL's Avatar
Originally posted by Ryde _Or_Die
Acura Integra GS-R
Acura. That's a Honda, right? Does any Honda besides the NSX even get into the 14's?
To try to help answer the thread starters question, I think you should get a pair of NITTO drag radials. You'd have a hard time spinning the tires.
Mike
Old Feb 5, 2002 | 03:33 PM
Erik's Avatar
Best of both worlds
my neighbor has a nice 95 GSR...intake, catback
i've never raced him but he took me for a spin in it one time. i was un impressed. i thought it was gonna be a lot faster that it was. i would say its only barely faster than my n/a. if i took out a little weight i'm sure i'd stay dead even with him.
i've also raced a random GSR on the street. i know he had at least catback, and intake (AEM stickers), and possible headers. it was pretty loud. we both rolled out of a stop light and then looked at each other and gunned it. by 70 he had about a fender length on me...
Old Feb 5, 2002 | 03:59 PM
SpeedRacer's Avatar
Formula Mazda Driver
Stock for a stock a 89-91 will probably barely lose to a GS-R with equal drivers. They have 10 more HP(170 vs 160) and better low-end torque. Plus their tranny's have a shorter ratio, and they can shift faster than any 2nd Gen tranny I've tried shifting. My brother used to always just BARELY pull on me in a race to 80 he'd be maybe 2 car lengths ahead, and then I'd slowly pull and we'd be almost even at 100mph. To beat an Integra with Intake and catback, I'd say you would probably need intake, racepipe, catback, and make sure you take as much weight off your car as possible. If you remove your airpump, PS, and AC, then you should have no problems.
Old Feb 5, 2002 | 04:03 PM
Boosting_FC's Avatar
Mike,
Yes. S2K, Acura RSX Type S, and the late Type R. Those are 14 sec cars (low and high, respectively).
sublimeracing,
An '89 Celica GTS would not beat a GSR. The Toyota is much much heavier (by something like 300 pounds) and has only a ~135 hp engine. A GSR is a 170 hp car at only around 2600 lbs. You do the math...maybe the guy you raced sucked.
nitrouspeed2,
I drove a Type R (intake, header, cat-back, cam, ECU, and some other)for 3 weeks when my buddy went on vacation. It was a fast car. I think it could do a mid 14. Extrapolating that to the GSR w/ only intake and cat-back, I think the GSR would do around 15 flat. So the goal is to get your car to below 15. Your '91 GTU would probably need: intake, header, gut cat or mid pipe, cat-back, and good traction to get 15. Lose as much weight as you can will also help.
Jay
Old Feb 5, 2002 | 04:04 PM
Thanks guys that helped alot, i will be custom building a exhaust, buying some headers,and buying a intake within the next couple of weeks...
Hey i know it's off the subject, but i cranked up my 1st gen 85 gs, a sec. ago, and the rpms just go straight up, till i have to turn her off, i looked under the hood, and i dont see the throtte cable stuck, whats the prob? its been about 2 months since i ran her. and it's a 12a, please help
Old Feb 5, 2002 | 04:35 PM
menace's Avatar
Acura Integra GS-R
i thought u guys were talking bout a mitsi lancer gsr and they can b prety mean...
Old Feb 5, 2002 | 06:23 PM
Drakk0r's Avatar
Check out my mods in my sig... All that, and I still loose by a car length in a race from a stop to 120. This was to a 94 GS-R with only a cold air intake. And BTW, for those who have never driven an Integra... If you've ever felt how well it shifts, you'd no longer be making fun of the "I shift mad qwik yo!" line we all make fun of..
Old Feb 5, 2002 | 06:33 PM
The real Lancers (EVO X) are not avail in the North America market...well maybe not until next year w/ the VII. We currently only have the crappy 120 hp lancers. The EVO VII is going to be parked right next to my 7 next year!!! Wow, two 7's next to each other...
Jay
Old Feb 5, 2002 | 06:36 PM
Snrub's Avatar
You're missing the other obvious one S2000. Very cool car.
Old Feb 5, 2002 | 06:43 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
my friend has a gsr and we timed it 0-60 at like 7.1-7.5
Justin
Old Feb 5, 2002 | 06:56 PM
von's Avatar
von
Hey... Thier not slow. Might even take u on surprise. When I was stock a LS beat me by a car through third. He had bolt ons. A GSR with bolt ons will spank U unless u have heavier mods than that...just my educated guess.
Old Feb 5, 2002 | 07:00 PM
Not to bust on anybody...but the GSR? I hope your referring to 96 and newer..the 93 and older GSR are mad slow! I am buddy's w/ a guy who has a '93 GSR w/ intake, exhaust, and cams...my 88 back when it was NA w/ straightpipe, bad throwout bearing, and intake, I beat him by a car's length from 0 to 85. He did however get a new shortshifter that I was playing with, and yes..those cars do have "mad shifting yo"
Old Feb 5, 2002 | 08:34 PM
Erik's Avatar
Best of both worlds
actually, i belive the older GSR's you're talking about are rated FASTER than the newer ones...all the stats i've seen have them turning in faster times
Old Feb 5, 2002 | 10:10 PM
mazdatypeR's Avatar
Newbie
what you need
hmmmmmm
I think you just need some light footwork. THE INTEGRA IS SLOW COMPARED TO A SEVEN. BUt you could buy a header so the integras intake doesnt over take the sound of your car. THATS all you need, cuz my red 86 SE dusted a lot of GSR's in its time
Old Feb 5, 2002 | 11:07 PM
Drakk0r's Avatar
Re: what you need
Really? Well, you've either got one fast N/A, or you've got to be drowning in your own bullshit... I'm not flaming you.. I know the car gods have made some sevens faster than others in stock form for no apparent reason.. But I have a hard time believing your post..
Originally posted by mazdatypeR
hmmmmmm
Old Feb 5, 2002 | 11:25 PM
kim307's Avatar
Don't underestimate the power of vtec. My Turbo II that ran low 14s beat a integra GSR with just I/H/E by only one car length. Depending on the driver, the GSRs could go deep into 14s.
Jay Kim
Old Feb 5, 2002 | 11:49 PM
menace's Avatar
Jay
so u dont have lancer gsr which range from 2L to 1.8 turbo and some r allwheel drive and some r front wheel... they have too many here(N Z)...
