TA/TV 45 or 51 Turbo bb conversion
Old Feb 23, 2006 | 03:02 AM
myfc3s's Avatar
That's what she said...
Hello,
Just wanted some input from you turbo experts out there. I have a T51s and wanted to covert the bushing to a BB. I really have no complaints on my turbo now. But i want to hear this thing whistle like the big riggs and of course spool a little earlier. Has anyone ever done this? please give me some input to a direction i should go?
Old Feb 24, 2006 | 04:11 AM
bcty's Avatar
Boost This!
you wanna hear it whistle get the antisurge front cover on it, that should do it. I believe the BB units are one piece so youd have to order one to fit im sure any knowledgeable turbo shop should be able to do that for you.
Old Feb 24, 2006 | 02:57 PM
myfc3s's Avatar
Hello. I have done a search on this antisurge front cover, and i have no luck. Also how does this thing look like? thanks in advance "bcty"
Old Feb 24, 2006 | 11:14 PM
bcty's Avatar
Boost This!
like that
Old Feb 26, 2006 | 04:32 PM
myfc3s's Avatar
I see that thanks, So all i do is remove the front cover off? to better explain myself can you please check my vbgarage and tell me if i remove the pce were everyone usually clamps there airfilter is at on my turbo. Will that make that sort of noise i am looking for?. The turbo i have now, has three allan like bolt for on that paticular area on the cold side. I want to call it turbo "horn" but im sure there is another name for it.
Old Feb 27, 2006 | 07:20 PM
RacerXtreme7's Avatar
NASA geek
Your going to have to remove and replace the entire front cover. Pull the hose/filter off the inlet, undo the disscharge, and take off the V-band clamp holding it on, then pull the entire front cover off. Reverse order for the new comp housing. It will kill spool a little bit and the top of the efficiency, but add to the left of the flow map (surge line). I personally would not trade off a little effiencey nor spool to "have a cool sounding turbo". You'll have to buy the comp cover from a Garrett disstributor. And no, ball bearings doesn't make any much noise difference at all, its the anti-surge housings.
~Mike.........
Old Feb 28, 2006 | 07:51 PM
myfc3s's Avatar
Make sense, thanks for your help Mike.
ChrisRX8PR
Aug 21, 2015 01:56 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
