Finally a little progress on the 20b install
Old Feb 20, 2006 | 04:26 PM
sillbeer's Avatar
Finally the engine is in the car. After 6 months of working on it for an hour here and there. What did others do for a throttle cable bracket? I'm not sure what to make? I had a q45 tb on it before and the bracket was pretty simple.
-Destin
Attached Thumbnails Finally a little progress on the 20b install-dsc01278.jpg   Finally a little progress on the 20b install-dsc01282.jpg
Old Feb 20, 2006 | 05:29 PM
bcool's Avatar
Rest In Peace Dave
-Destin
Hrmmm, i ended using an FD throttle body, but i just cut a peice of metal and bent it to shape, knotching it and drilling holes for the screws, works perfect.
Old Feb 23, 2006 | 06:21 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
http://www.teamfc3s.org/forum/showth...5&pagenumber=3
this is a 2-rotor cosmo, but you can see how i did the bracket there...piece of cake.
Old Feb 23, 2006 | 10:30 PM
sillbeer's Avatar
That does look easy. Thanks.
-Destin
Old Feb 24, 2006 | 12:16 AM
one thing to note though, pay attention to how long it is. that position hooks onto the cruise control thingy. you may have to play around with where you set your cable to make sure the throttle will still open up all the way. the cable will more than likely be run in without much slack.
i don't wanna read any threads a few months from now about how your 20b only did 190 whp because the throttle wouldn't open up all the way
Skeese
65
Mar 28, 2017 03:30 PM
lt1_rx7
Blue Ridge Rotary Run
46
Oct 9, 2015 03:11 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
