Mallory 6A wiring question
Old Feb 18, 2006 | 10:58 PM
RotaryX's Avatar
ROTARY AUCTIONS
Question Mallory 6A wiring question
On my leading coil there are 4 wires. But in the following Diagram there are 5 wires. So my question is what wire is not needed?
The diagram Shows the amp having a IGN, +, and -. Is the white wire not needed?
Old Feb 18, 2006 | 11:21 PM
Icemark's Avatar
http://www.fc3spro.com/TECH/HOWTO/CDI/cdi.html
yellow and green and purple are not used.
Yes, you must use the white wire... it goes to the ignitor side of the (-) coil wire that you cut.
Old Feb 18, 2006 | 11:51 PM
RotaryX's Avatar
ROTARY AUCTIONS
So the wire that say "TO IGNITION SWITCH", does not exist on our cars?
I'm also installing a micro-tech. Where does the ignition output wire-up to? Its only one wire, and I believe that its a trigger wire.
The Shaolin
Sep 14, 2015 07:50 PM
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
