Having real troble getting the engine stabbed
Old Feb 18, 2006 | 09:48 PM
slo's Avatar
slo
registered user
I am having a huge amount of trouble getting the engine stabbed on the transmission. Here are the specifics, the engine is a 13b-RE, the trans is a stock s5 auto, I put the original flexplate on the RE. I have the stainless mount adapters sold by another lister. I just cant seem to get them lined up and clearing everything. I think it will, but its so ******* tight.
I have all the right tools, and Ive never had a problem getting an engine in a car before, any advice would be most appreciated....
Thanks,
Old Feb 18, 2006 | 10:17 PM
staticguitar313's Avatar
R.I.P. Icemark
whoa there, AUTOMATIC? but why are you missing function in a limb?
Old Feb 18, 2006 | 10:32 PM
slo's Avatar
slo
registered user
I have a 5 speed in my garagage. And I'm going to do the conversion at some point, but It going to cost another 700 bucks to get the rest of the parts I need.
Old Feb 19, 2006 | 02:00 PM
slo's Avatar
slo
registered user
If anyone else happens to find this thread in a search, and your having problems stabbing an auto trans, don't do what the book says and set the torqe converter at 33 mm, simply push it all the way in, this was the problem. Once you connect the engine and trans there is enought length on the torqe converter bolts to pull the assembly together (torge converter and flexplate).
Old Feb 19, 2006 | 02:24 PM
Aaron Cake's Avatar
Engine, Not Motor
I've never done the automatic, but I find that when installing the engine with the transmission already in the car the engine mounts MUST be removed first or you're in for a world of pain lining it up. Hoist the engine into place, mate it with the transmission then install the mounts afterwards while it's still supported by the hoist. Just don't let the assembly hang by the transmission.
C. Ludwig
Jan 30, 2019 06:31 AM
elfking
Aug 19, 2015 09:48 PM
Wolf_
Aug 11, 2015 04:23 PM
