one single beep??
Old Feb 17, 2006 | 01:12 AM
bobafc3s's Avatar
FC3S Cruiser
Exclamation one single beep??
when i was driving, guages, temp, oil pressure were all in normal ranges. i was in the left turn lane waiting to turn cuz there wasnt left signal just yeild to traffic. and i rev up a little n move forward and i hear one single beep. i dont know what it was can anybody tell me?? sort of sounded like "DEET"
Old Feb 17, 2006 | 01:32 AM
Tournapart's Avatar
RIP Icemark
that pretty much means your about to blow your engine, check your coolent overflow for chocolete milk, sorry man
did you redline? if not then
sorry, i couldnt resist, check your body computer for loose connections and bad solder joints if the problem persists, im sure it was just a fluke, there are worse things in these money beasts
Old Feb 17, 2006 | 01:43 AM
RboYi's Avatar
what RPM were u at?
Old Feb 17, 2006 | 10:18 AM
Icemark's Avatar
sounds like low oil or low coolant buzzer. Check both.
and the body computer would have nothing to do with either of those.
Old Feb 17, 2006 | 01:45 PM
bobafc3s's Avatar
FC3S Cruiser
i was at 1500rpm it was a very faint beep. i checked oil this morning a tad below the first X. should be fine. ill check coolant levels, it seemed fine when i checked tuesday.
Old Feb 17, 2006 | 01:52 PM
Icemark's Avatar
If you squeeze the top rad hose do you hear any bubbles???
If you do, you have air in the cooling system.
and what X on the dip stick... the top ones (nearest to the handle) or the bottom ones (nearest to the end in the oil)?
Old Feb 17, 2006 | 11:22 PM
bobafc3s's Avatar
FC3S Cruiser
top X on the oil stick. i will try squeezing thanks icemark
Old Feb 18, 2006 | 12:32 AM
Alex6969's Avatar
The Silver Bullet
was it a "BEEP" or was it an "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!!!!!!" the sound like the devil is gonna rip out of your head?
any idiot lights lit up?
Old Feb 18, 2006 | 12:50 AM
jhammons01's Avatar
Carter 2.0
Next time it does that, Take a right handed turn at fast speeds. If it is oil then you'll know without having to check.
I hate that buzzer. if it goes off like that you have no way of knowing what it was......just as you described.
Old Feb 18, 2006 | 12:59 AM
bobafc3s's Avatar
FC3S Cruiser
it was a beep that lasted 1 second only. ohh and while im at it when i take right hand turns at a faster speed the "washer" fliud light lights up. is there anyway to unplug it or something because i dont have washer fliud and it hasnt been used in a long time.
Old Feb 18, 2006 | 01:05 AM
snowball's Avatar
I live in the lounge...
i think he would have said if it was the "AAAAAAAAAAAAAAAAAAAAAAAAA" i thought my car was about to explode....
Old Feb 18, 2006 | 01:14 AM
Tournapart's Avatar
RIP Icemark
sorry for the misinformation, i just kinda figured the body computer might have had a hand in the weird beeping sound
Old Feb 18, 2006 | 10:32 AM
Icemark's Avatar
Body computers only beeps when the key is in the ignition and the door is open,
or the car is not running and the door is open and the lights are on.
Old Feb 18, 2006 | 10:35 AM
jgrts20's Avatar
Who are you?
bubble in the coolant, maybe!!
Old Feb 18, 2006 | 10:44 AM
AbortRetryFail's Avatar
Trunks are for corpses.
If it's a BEEP it's probably the power steering computer. if its like AAAAAAANGH then it's the coolant/redline buzzer everybodys talking about.
The power steering computer beeps different beeps for different things, the FSM has what it all means.
I know once my tach quit working and my power steering computer FREAKED out. beeping and all kinds of crazy ****.
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
demetlaw
Oct 2, 2015 06:22 PM
93FD510
Oct 1, 2015 02:00 PM
