Grant steering wheel install?
Old Feb 14, 2006 | 06:38 PM
blackjack's Avatar
Exclamation Grant steering wheel install?
Already installed in my 7 when i got it but it moves in and out. why? How do i fix it. i have no directions and i have never done one before. thanx for the help
Old Feb 14, 2006 | 07:25 PM
misterstyx69's Avatar
Retired Moderator, RIP
did you buy the hub adapter?..
Old Feb 14, 2006 | 08:35 PM
Taikutsu's Avatar
sounds like the nut that holds the hub on might be loose?...so just unbolt the 5 hex screws that hold the wheel on...then tighten the nut holding the hub
Old Feb 14, 2006 | 08:49 PM
Tranquil's Avatar
Wankle Waffles
You broke the plastic on the collapsable steering rack.
You're boned.
Old Feb 15, 2006 | 03:14 AM
blackjack's Avatar
tightened all the bolts underneth the horn button seemed to help some. what is this plastic thins on the collapsable colum and why am I "BONED"?
Old Feb 15, 2006 | 09:17 PM
blackjack's Avatar
So what is this plastic that i may have broke? can it be fixed or what?
Old Feb 16, 2006 | 01:56 PM
Tranquil's Avatar
Wankle Waffles
The little plastic piece is what stops the steering column from collapsing. It is designed in a collision to break so that the column does not impale you by not collapsing.
Its a common mishap when installing a steering wheel.
And you can do nothing about it other than purchase a new rack.
Old Feb 16, 2006 | 05:57 PM
blackjack's Avatar
new rack? i have manual steering. going to look in the books tonight.
Old Feb 16, 2006 | 06:44 PM
Tranquil's Avatar
Wankle Waffles
A simple forum search uncovered some of RX7Carl's invaluable information regarding this. Give it a read, it should answer all of your questions.
https://www.rx7club.com/showpost.php...51&postcount=4
I'm also quite surprised that in this entire interior/exterior forum I'm the only one that could answer this question. Either the guys are slacking, or don't know anything.
Oh and "boned" is a term frequently used by a cartoon character named Bender from a show called Futurama.
I hope this solves everything for you. From the beginning I was assuming the movement you spoke of was an "in and out" from the shaft. That would be your column wanting to collapse.
Old Feb 16, 2006 | 10:35 PM
blackjack's Avatar
What SHAFT are you refering too? ok here it is. ( I didnt get into the books like i need too) the steering wheel sits flush and everything works great except if i pull with fair amount of force toward the roof..inline angle of steering coloum.... it will pull out about 1 " haven't tried to turn it too much but i am pretty sure the horn doesnt work then but not totally for sure on that. will look at it further tomorrow. It doesnt move real easy but if you get in using the steering wheel it may pull out. I just need it to pass a one time inspection here in MD. Thanx and sorry for the agravation.
Old Feb 16, 2006 | 10:37 PM
blackjack's Avatar
heres a pic of my inside. will try to get better pics of it pulled out tomorrow.
Old Feb 16, 2006 | 10:40 PM
here https://www.rx7club.com/search.php?s...=1616625..this is all under steering column play ..found by Search..best to ya..get her fixed..it is dangerous ..(lookin out for ya bro..)
Old Feb 17, 2006 | 11:10 AM
blackjack's Avatar
anyone have picks of the rivit fix? I sorta understand it but i just dont see how it works. man i hate surgeries. i cant really get out and look around underneth. So we'll see . thanx guys at least i dont have to buy a new one and then remove and replace it. I just barely kept this car. I dont want to do any major work to her to keep it worthy of keepiing. I still have to get it inspected. i guess that will be next week. THanx
Old Feb 18, 2006 | 06:21 PM
Tranquil's Avatar
Wankle Waffles
Shaft? Steering column.
Shaft, column, synonyms.
Th0m4s
Feb 26, 2019 02:04 AM
