15" weld wheels FD
Old Feb 14, 2006 | 05:23 PM
willjs7's Avatar
3 and the hit for $100?
15" weld wheels FD
I want a set of 15 inch weld wheels on the rear of my FD. I'm getting the pettit rear fender flares, and was wondering how wide i should go, what bolt pattern i need, along with what spacer i need.. and any tips or pics on trimming the caliper?
P.S i want them wide
Old Feb 14, 2006 | 05:50 PM
maxcooper's Avatar
WWFSMD
The bolt pattern is 5x4.5".
Are there rules for the class you intend to race in that govern wheel and tire choices?
-Max
Old Feb 14, 2006 | 06:02 PM
willjs7's Avatar
actually, i was planning on running them on the street.
Old Feb 15, 2006 | 09:14 AM
LUPE's Avatar
What kind of tire are you wanting to go with? ET Street or a radial tire?
Old Feb 15, 2006 | 07:13 PM
willjs7's Avatar
a drag radial.
Old Feb 15, 2006 | 07:26 PM
LUPE's Avatar
Originally Posted by willjs7
a drag radial.
Well, there is no reason to get a wide wheel when you can only get a 275 series tire and keep a 26 inch tall tire. If you go any taller, it will look stupid.
http://www.mickeythompsontires.com/strip.html
BFG's are the same.
Old Feb 16, 2006 | 07:00 AM
willjs7's Avatar
i need wider. b/c im getting rear flares, i need to fill up the space in my wheel well. i dont think a 275 will be enough. what do u think?
Old Feb 16, 2006 | 06:26 PM
LUPE's Avatar
It won't be enough......... You'll need to either get a regular performance tire under there or use a 275 drag radial with the right offset wheels.
Old Feb 20, 2006 | 04:42 PM
willjs7's Avatar
so another question, where would i get the proper wheel spacer needed for these wheels
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
