Really odd
Old Feb 14, 2006 | 03:56 PM
13bjuice's Avatar
Really odd
i have an 88 n/a and the car runs great. i just got it tuned out,tps timing and such, but when i shut the car off and come back to drive it again, i noticed a fresh spot of oil on the ground. I looked for a path but couldnt find one and when i opened the hood i noticed a film of oil on the pullies?!?!? Now im really confused. Is my baby going to die?
thanks in advance for your help.
Old Feb 14, 2006 | 04:30 PM
classicauto's Avatar
Crash Auto?Fix Auto.
you'll need to look right under the car and find the leak...
I would recommend checking the lines for the oil cooler, they are prone to failure
Old Feb 14, 2006 | 04:32 PM
Icemark's Avatar
yeap if it is on the belts, I would look at oil cooler lines or fittings.
Old Feb 14, 2006 | 04:36 PM
13bjuice's Avatar
so you dont think its an internal failure of some sort?
Old Feb 14, 2006 | 06:26 PM
HAILERS's Avatar
HAILERS
Get a flashlight and a inspection mirror. Look directly into the front pulley bolt area. It should be bone dry. If there is oil there, see if the front pulley bolt is loose.
Another area that leaks oil is the omp lever. The lever has a o'ring. After fifteen plus years it wears and will leak oil drops. Look at the omp. It should be bone dry and the oil lines on the omp should not be leaking a drop.
Old Feb 14, 2006 | 06:29 PM
torean's Avatar
vac leak
helps if u clean off the old oil first..when the car is cold.....spray some carb or engine cleaner to dissolve the oil first...so when u come back the place with the most oil would/should be what ur lookin for
Old Feb 14, 2006 | 11:38 PM
13bjuice's Avatar
OMFG i just went out there to check that main pully polt and that bitch was hanging on by a thread. Good call man, i would have been SOL if i would have left in the morning
Old Feb 14, 2006 | 11:46 PM
Nick_d_TII's Avatar
Good call! and A Great save!!!
Old Feb 15, 2006 | 12:10 AM
eriksseven's Avatar
Make Money.
The E-shaft bolt?!?!?!
Old Feb 15, 2006 | 12:16 AM
jhammons01's Avatar
Carter 2.0
DO NOT Try to tighten it back!!!!!!!!!!!!!!!!!!!!!
There is a process for reseating the bearings for the "end play" (search for "End play") The Roller pin bearings fall or slide downward when that big 19mm Eshaft bolt is loosened. You need to take the front cover off in order to VERIFY that the roller pin bearing is properly postioned.
IF YOU TIGHTENED that 19mm already there is a huge chance that you crushed this bearing.
1NSIGHT
Drifting
Sep 29, 2015 12:18 PM
Rotospectre
Sep 13, 2015 11:22 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Aug 14, 2015 04:18 PM
