Sponsored by: CARiD
1983 12a runs like crap
Old Feb 12, 2006 | 06:32 PM
ben_liffrig's Avatar
Newbie
i have a 1983 rx7 12a. i drove it home from where i got it and it was not pretty. For starters it needed to be reved up to about 3k to let clutch out with out killing it. I replaced the plugs, plug wires, fuel filter. I cleaned the carb and am lost now.
Old Feb 12, 2006 | 09:54 PM
triplestack's Avatar
Newbie
Man i'm having the same problem with my 85' 12a with no luck. if you figure anything out please let me know.
Old Feb 14, 2006 | 10:36 PM
Newbie
what have you all tried to fix it?
I am going to look into the timing
Old Feb 17, 2006 | 09:15 AM
IanS's Avatar
Ricer
Check in the FAQ in the first gen section. Could be a vac leak, or even a bad engine. Pull the spark plugs, crank over by hand and see if there is a noticable difference in the pulses. They should be even, and cosistent.
Th0m4s
Feb 26, 2019 02:04 AM
highspeedrider
Aug 19, 2015 03:44 AM
rx7brandon
Aug 16, 2015 10:55 AM
zuesskroph
Aug 13, 2015 06:05 PM
