Tps Adjustment
Old Feb 12, 2006 | 02:32 PM
Tps Adjustment
Tried Tps Adjustment Using Two Bulbs,both Bulbs Stay Lit Regardless Of Where I Adjust The Screw,is The Tps Defective? Is There Any Way To Test For Sure As They Are Rather Expensive.problem Is Engine Surges At Approx 1500 Rmp Otherwise Runs Great On Acceleration,top End,and Idle.please Advise. George Bates
Old Feb 12, 2006 | 02:40 PM
gsl-se addict's Avatar
Super Moderator
Do you have a multimeter? You can unplug the TPS and check the resistance between the each 'eye' or the connector and the 'mouth'. Each one should vary between 1k and 5k as you move the TPS plunger in and out. One will decrease as you push in and the other will increase.
You can also get a used TPS as the new ones are so expensive. The TPS can cause some strange behavior on the SE when it is bad or out of adjustment. Can you get one or both lights to go out if you push the plunger in or open the throttle?
Old Feb 13, 2006 | 06:56 AM
frisbeedog's Avatar
I'm in love with Daisy
I built my TPS tester with two resistors and male- female connectors, it has worked great. Radio Shack had all the parts for around 6 bones. I will try to find the writeup for this model tester.
When you say your car is surging are the RPM's jumping up and down? Or is this something that happens when you are trying to be steady on the gas and the car cant keep a steady pace?
Also do some searching on for threads from longduck. He has done some great writeups for us SE guys.
Old Feb 13, 2006 | 12:16 PM
Surging Occurs At Steady Engine Speed,approx 1500-2000 Rpms
Old Feb 13, 2006 | 01:55 PM
frisbeedog's Avatar
That almost seems like bucking caused by gas in the oil. When was the last time you changed your oil? Has the car flooded recently?
I'm not great at trouble shooting GLS-SE idle problems, so nobody flame me.
Old Feb 13, 2006 | 05:15 PM
This Problem With The Surging Seemed To Start After The Battery Was Disconnected For About For About A Week,oil Is New,surging Is Driving Me Nuts Hard To Drive At Low Speed Because It Bucks, Need Some Help As No One In My Area,cincinnatti,ohio Works On Older Rx7s.
Old Feb 14, 2006 | 09:09 AM
deimox's Avatar
Never again I said....
Hello, I had a similar problem several months back. I thought my tps was dead, turned out the car was just horribly timed (had just bought it). If nothing else one more thing to make sure its on the up and up since timing is fairly damn easy.
Adam
Old Feb 14, 2006 | 04:10 PM
Bteets9914's Avatar
The bucking can definately be caused by the TPS being out of adjustment. One of the things that you might want to try to do also is to remobe the TPS and push the plunger all the way in and let it come all the way out. You have to figure that the range that it is used is extremely short and this area can have a little bit of wear or even crap on it, moving it full length can also help.
The other thing that i did was to use a multimeter to get the TPS adjustment close (about 1K, which is where it is supposed to be set at idle), then use the light rigg to dial it in. That way you know you are at least in the ball park when you try to do the fine adjustments using the lights.
Hope this helps,
Bryan
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
Turblown
Sep 30, 2015 05:58 PM
rotor_veux
Sep 28, 2015 09:25 PM
