stock fpr and 1600's
Old Feb 12, 2006 | 10:38 AM
charlies7's Avatar
3rd rotors a charm
just wondering if the stock fpr will fine to use with a ugraded rail and 1600cc injectors. Its not going to be a long term setup. Any opinions??
Old Feb 12, 2006 | 03:54 PM
charlies7's Avatar
3rd rotors a charm
anyone im planning on gettin the kg rail.
Old Feb 12, 2006 | 04:23 PM
willjs7's Avatar
3 and the hit for $100?
no, there is no way to use the stock FPR with an aftermarket rail
(i'm almost positive)
Old Feb 13, 2006 | 08:29 AM
Silver7's Avatar
The stock secondary rail can be modified to use top feed 1680cc secondaries. If this is what you are doing then you can use the stock FPR. I have done this in the past and a friend of mine is currently using this setup.
Old Feb 13, 2006 | 10:38 AM
NewbernD's Avatar
Tequila? ..it's like beer
Just to clarify, you are speaking of having done this to a 3rd gen with a side feed secondary rail? I'm curious to know what ths mod looks like and how it was accomplished.
Old Feb 13, 2006 | 10:48 AM
signofinfinity's Avatar
Coyote
yeh me too!!!!
i cant see how its done.... thats amazing. post some pics please....
Old Feb 13, 2006 | 06:30 PM
charlies7's Avatar
3rd rotors a charm
doesnt matter anymore....i bought a completely new system.
Old Feb 14, 2006 | 06:56 AM
Silver7's Avatar
I will look for a pic and post it up when I get home from work.
Old Feb 14, 2006 | 12:10 PM
Coyote
Thanks! I would love to se this mod!!!!
George
Old Feb 15, 2006 | 03:30 PM
Silver7's Avatar
Here are the pictures of the modified secondary fuel rail.
Old Feb 15, 2006 | 03:38 PM
heatdriver's Avatar
Run, Run, FD!!!
What are the necessary mods????
Old Feb 15, 2006 | 03:40 PM
Silver7's Avatar
I'm not exactly sure what you are asking.
Old Feb 15, 2006 | 04:00 PM
heatdriver's Avatar
Run, Run, FD!!!
Sorry...
I mean... how did you make it fit? I thought that 1600cc's didn't fit...
did you use some special o-rings or something?
Old Feb 15, 2006 | 04:08 PM
Silver7's Avatar
The top three holes of the rail need to be sealed off (welded or JB weld). Spacers are used to set the rail high enough to sit on top of the injectors. I think I did use smaller orings around the top of the injectors and the bottom injector holes were drilled out a little.
Old Feb 15, 2006 | 04:34 PM
NewbernD's Avatar
How about that action.. golf clap to you for the ingenuity. I like it.
Is there anything inside of the rail that "holds" the injector in there besides the o-ring? What I mean is, is there some sort of stop in the side feed housing or could enough boost pressure push the injector up inside of it?
Old Feb 15, 2006 | 05:03 PM
Silver7's Avatar
The opening is enlarged but not drilled all the way through. There is a small lip that stops the injector from being pushed into the rail.
I can't take all the credit here. I saw it done elswhere and at the time and I had a very small budget so I used this setup until I could make my own custom primary and secondary fuel rails to house primary and secondary top feed injectors (which turned out to be protoype versions of the KG rails.)
Old Feb 16, 2006 | 01:16 AM
Coyote
damn..... thats sweet!! thanks for the pic!!! lol that seemed fun to do!!
nice thinking
George
Skeese
65
Mar 28, 2017 03:30 PM
Clacor
Aug 14, 2015 09:17 AM
