:( Well I think my engine is shot
Old Feb 10, 2006 | 04:33 PM
dj55b's Avatar
Well i think that my engine is finally shot ... check compression ... the rear rotor is showing no compresion. Now i'm trying to figure out what to do ... Mazdees is a pretty far ride from here ...but looks like i might just get it transported there unless someone has a better idea. PLease i'm open to anything right now
Old Feb 10, 2006 | 04:46 PM
gsl-se addict's Avatar
Super Moderator
Doesn't sound good. My SA did the same thing. It tossed an apex on the rear rotor causing 0 compression on the rear. It still drove okay, just had no power at all. Did you try cranking with a plug out on the rear rotor and listen for the 'puffs'?
Do you have a place to work on it where you live? I ended up using a wrecking yard engine in the SA. Didn't take much time or tools to swap. Good luck.
Kent
Old Feb 10, 2006 | 05:45 PM
Mazda12AGS's Avatar
I swapped the engine and trans into mine in a day.
Old Feb 10, 2006 | 08:38 PM
dj55b's Avatar
in the junk yard here there's only 3 sa's and i'm really not sure on the condition of the engines they seem pretty rough. I did the compression check with an actual tester. So the readings have to be right.
Old Feb 10, 2006 | 11:12 PM
R.P.M.'s Avatar
Likes to swear....alot
My shop is only a couple hour drive north of you
What motor do you have? 12a or 13b ?
Old Feb 10, 2006 | 11:22 PM
dj55b's Avatar
where abouts are? Whats your shops name? I have a 12a engine
Old Feb 10, 2006 | 11:23 PM
85rotarypower's Avatar
love the braaaap
Motor is deffinatly shot. I remember when my 12A ate one of the apex seals on me. It was during startup, of all times. Car was VERY low on power and had a very hard time idling, but it was drivable. Probably could have drove it for a while if I upped the idle on the carb to keep it running. Actually sounded kinda cool, somewhat like a 20B, if you can imagine that, just rougher sounding.
Old Feb 10, 2006 | 11:34 PM
blwfly's Avatar
kiwi from downunder..
when a engine shots a apex does it do damage to the housing??
Old Feb 10, 2006 | 11:44 PM
love the braaaap
Most of the time, yes. As the apex bounces around in the rotor housing it can do a great amount of damage. I have a blown TII shortblock that I tore apart to find that all three apex seals were shattered on the rear rotor and the whole rear rotor and housing were garbage. There was gouges so deep you could see them from a distance, and there was actually an impression of a piece of an apex seal on the face of the rotor. If i had the piece it would have fit right in there.
Old Feb 10, 2006 | 11:46 PM
R.P.M.'s Avatar
My shop is just out side of Walkerton. Just go straight up Hwy 4 out of London until you hit Hwy 9, then I'm only 10mins from Hwy 4&9.
My shops called R.P.M. Rotary Performance and Maintenance
Enigine building is my specialty
Old Feb 11, 2006 | 12:13 AM
blwfly's Avatar
can your repair gouges lets say welding or is it a throw away
Old Feb 11, 2006 | 12:23 AM
R.P.M.'s Avatar
No once the housings have major gouges in them...they are pretty much junk.
But if the housings have some scraping or the chrome surface is flaking off, then JHB can re-coat the housings with a Cermet coating. They work real good too. http://www.jhbperformance.com/
Old Feb 11, 2006 | 12:30 AM
dj55b's Avatar
Have you built anyone's engine from this forum? I just want to see your work. How much do you charge for a 12 rebuild? Also how long does it usually take to rebuild?
Old Feb 11, 2006 | 12:35 AM
R.P.M.'s Avatar
Yes, I've built a few motors for forum members.
Send me an email to rx7_wankel@hotmail.com I'll send you some pics of porting and engine builds I've done before.
Microtech
30
Apr 23, 2016 06:37 PM
ppritchard
Interior / Exterior / Audio
Aug 21, 2015 06:02 PM
