a few carb questions
Old Feb 10, 2006 | 01:31 PM
nfld85GS's Avatar
I just picked up a weber 48 ida carb from RB for my 85 GS and i need to know what are some good jet settings to make it run well. I have a 12a with RB exhaust, MSD 6a box with Blaster 2 Coils. I currently have the factory settings but i know they will need adjustments. I have searched and found many settings with my setup except they were all streetport (which will be coming this fall sometime).
Secondly, on the weber carb there is only a fuel in. do i have to make a fuel return line for the carb, or can i just run it at a lower PSI such as 2-2.5 so i don't flood it? i have a carter 8 PSI fuel pump with a holley 1-4 PSI regulator and a summit pressure gauge.
Lastly, the intake manifold has a hole on the left side (looking from passenger side), is this for the brake booster line? if so what type of adapter do i need to fit in that hole? There are also two little holes on the front of the intake which i have no idea what they are for. I haven't had a chance to look at my current intake since the car is in storage right now.
I hope these questions make sense! Thanks for you help!
Phil
Old Feb 10, 2006 | 03:48 PM
Siraniko's Avatar
RX for fun
http://www.aircooled.net/gnrlsite/re...idarebuild.htm
http://www.vwtrendsweb.com/tech/0308vwt_carb/
Read on then PM me your specs and questions.
Old Feb 10, 2006 | 03:59 PM
nfld85GS's Avatar
I was hoping you would respond! Thanks for the articles. I'll read them as soon as i can tonight!
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
