Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
Is It Possible...
Old Feb 4, 2006 | 10:07 PM
dothacker's Avatar
Is It Possible...
is it possible to put a skyline engine in an FC? doesn't need to be an RB25 or RB26... an RB20 sounds good already... would it fit?
Old Feb 4, 2006 | 10:22 PM
philiptompkins's Avatar
anything is possible, its been done
Old Feb 4, 2006 | 11:44 PM
FromSilvia2seven's Avatar
wanna Hit 200+
people have fit SR20 motors in them all day RB20 is no different but i would recamend the SR over the RB.
Old Feb 5, 2006 | 12:36 AM
Nihilanthic's Avatar
moon ******
Yeah, it would fit, but there are much better choices unless youre simply thinking "skyline + FC"
It would mean custom mounts + a tranny crossmember, new DS... wiring and fuel lines and such. Same old ****.
Old Feb 5, 2006 | 12:37 AM
Cheesy's Avatar
except its a cast iron block and has 2 more cylinders
Old Feb 5, 2006 | 01:27 AM
digitalsolo's Avatar
RX-347
There would be MAJOR subframe modifications to do so.
But yes, it's possible. Can your wallet take the pain though?
Old Feb 5, 2006 | 01:50 AM
FCdemon's Avatar
3rd gen junkie
If you have to ask, then the answer must be NO.
Old Feb 5, 2006 | 03:00 AM
moon ******
I think you said it better than anyone here
Old Feb 6, 2006 | 09:30 AM
dothacker's Avatar
well, my wallet can take the pain... but would u recommend the SR over the RB? i dont know... or should i just stick with 13B? i'm having trouble playing around with the 13B and i know my way around SR's and RB's... that's why i'm asking...
Old Feb 6, 2006 | 12:23 PM
RX-347
Vs. RB and SR, I'd probably just keep the 13b. The 13B has at least the power potential of an SR, and with the difficulty you'll face getting an RB in, and the cost of parts for it, the 13B would be your most effective choice most likely.
...and this is coming from a piston guy.
Old Feb 17, 2006 | 05:19 PM
Cheesy's Avatar
or you could even build up an RB30DET
Old Feb 17, 2006 | 06:57 PM
moon ******
Or you could use a more cost effective piston engine if youre not all hung up on it being "jdm tyte" like a 3800 and a BOLT IN MOUNT SETUP from Grant :P
His 2.3T Mounts are up on the site now, granted youd like to play with a ford 4banger
str8ryd
3rd Gen General Discussion
401
Feb 11, 2025 01:21 PM
NeoZ06
Feb 26, 2009 12:21 AM
83gslRX-7
SE RX-7 Forum
Dec 7, 2008 09:07 PM
