Intercoolers?
Old Jan 29, 2006 | 09:22 AM
Intercoolers?
Ok i'm looking to get an Intercooler for a Fd thats Street ported etc but still running Twin's. I may be going to a singe but in a year or so.
I have done alot of reading up on Ic's and have come down to ether Apexi FMIC or the M2 SMIC.
I do a quite a few Track days but its mainly for Fast road
Which would you guys say go for? I know there both good but i'm put of the FMIC a bit becouse of the Problem with air flow to the rad?
I did think about using a V-Mount but i want to keep the cosmetics of the car as stock as poss so i don't want to fit a Vented bonnet.
So Apexi or M2?
Also has M2 got a new web site? i can't get there site up? Is there anywhere else that sells there stuff?
Cheers
Chris
Old Jan 29, 2006 | 09:25 AM
JDK's Avatar
JDK
If your doing track days M2 med.or large, FMIC will give you over heating problems.
Old Jan 29, 2006 | 10:21 AM
Ok, Next problem, Does anyone have contact details for M2? I will proberly end up with a M2 Med Ic.
I will be able to keep the Battery in Stock location with the mid?
Cheers
Chris
Old Jan 29, 2006 | 10:03 PM
Matt Hey's Avatar
Old School
M2 went out of business and the rights to produce the intercooler went back to Kevin T. Wyum and his business ASP. You can either contact him directly (he's on the board) or buy from rx7store.net...
http://www.rx7store.net/product_p/aspmedium.htm
Here's some more info on intercoolers with a bias toward stock mounts...
http://www.fd3s.net/intercoolers.html
A V-mount doesn't need a vented hood. All the intercoolers will benefit from a vented hood but it isn't necessary for any of them. The V-mounts can be quite expensive unless you need to upgrade the radiator at the same time. Rotary Extreme sells quite a few in the U.S...
http://www.rotaryextreme.com
If your on a budget and not in a big hurry then watch the for sale forum. There is a M2 medium and an Apexi FMIC for sell as I type...
https://www.rx7club.com/showthread.php?t=504353
https://www.rx7club.com/showthread.php?t=497496
Old Jan 30, 2006 | 03:27 PM
Cheers Matt. I have been looking at the for sale section but i did'nt see that M2.
Old Jan 30, 2006 | 03:34 PM
BoostedRex's Avatar
NorCal 7's Co-founder
I would recommend the ASP IC for what you want. Although, you don't have to fit a vented hood to use a V-mount IC. A vented hood just optimizes a V-mount setup, but a stock hood will still work great with a V-mount. Just thought I'd throw that out there.
Zach
ls1swap
Jun 3, 2024 03:25 PM
1NSIGHT
Sep 25, 2015 12:59 PM
MILOS7
Sep 18, 2015 03:39 PM
