Haltech anyone running constant duty coils?
Old Jan 26, 2006 | 10:24 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
if so, what do you have to say about them?
Old Jan 27, 2006 | 12:01 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
What coils do you know of that are constant duty coils, cause 95% of the worlds ignition modules (which are the ones responsable for firing the coils) are Constant Charge, Falling Edge, but if you are talking CDI, those are mostly constant duty, rising edge.
You will always need something to fire the coil with, either a built in driver or a built in ignition module or something external.
So, what are we talking about exactly?
Old Jan 27, 2006 | 06:52 PM
"smart" ignitors.
Old Jan 28, 2006 | 09:23 AM
EFI Tech Wannabe
You're talking about igniters again. Your original question was about coils. hehe
Just trying to clarify.
Old Jan 28, 2006 | 12:45 PM
i didn't want to get into a semantic debate over the way i phrased it. i figured anyone using them would know what i was talking about.
Old Jan 28, 2006 | 02:12 PM
EFI Tech Wannabe
No, ok, yeah, im with you, but i just want to know which coils are these, what model part number or where can they be found? How to tell if one is smart or dumb?
Old Jan 28, 2006 | 02:56 PM
i think haltech has smart and dumb fire setups on their website, but i haven't found them anywhere else yet.
my question is with constant duty;
if i set it for say 50%, does it change the coil charge time in proportion to that?
so charge time @ 7000 rpm would be just under 4.3 ms,
and charge time @ 1k would be ~30ms
or does it work another way.
reason i ask is because i can get my car to idle really lean with a really high charge time, but obviously, the duty cycle would be beyond 100% once i get into the higher rpm range. so i wanted to know if that's how the constant duty worked vs. the constant charge.
sherff
Feb 24, 2019 12:09 PM
Microtech
Aug 23, 2015 11:04 AM
ncds_fc
Aug 15, 2015 10:06 AM
zuesskroph
Aug 13, 2015 06:05 PM
Wolf_
Aug 11, 2015 04:23 PM
