CYM Tricoat Paint
Old Jan 21, 2006 | 02:21 PM
wilddog's Avatar
CYM Tricoat Paint
For anyone our there who happens to know. Since cym is a tricoat color, how hard is it to apply to the car?? I mean, how much of the mid layer do you add to the base coat? As well, Im guessing that since its a tri-coat, paint touch ups are next to impossible? Cheers
Old Jan 22, 2006 | 08:15 PM
wilddog's Avatar
nobody???
Old Jan 22, 2006 | 10:43 PM
SRA-FD3S's Avatar
paint is baked on
Old Jan 23, 2006 | 06:59 PM
Meiogirl's Avatar
the REAL deal
its a tricoat? i thought dupont came out with that in...94 or 95?
i always thought it was a yellow with a fine pearl metal flake in it.
Old Jan 24, 2006 | 05:57 PM
Rob XX 7's Avatar
FC guy
Originally Posted by SRA-FD3S
paint is baked on
??? what does that have to do with anything?
the tri in the tri coat is what gives the CYM its mica effect, its like a translucent pearl paint, applying this evenly is the key, if you put too much in one spot it will appear almost like a dirty area. The yellow is pretty straight forward, once the car is covered in yellow you go with the effect , then you clearcoat.
just be sure to get plenty of paint, it does not cover very well
Old Jan 24, 2006 | 07:01 PM
razorback's Avatar
You've Been Punk'd
you are right, i know because my friend just had his cym repainted.
Old Jan 25, 2006 | 03:30 PM
FNQuick's Avatar
Tri-coats can be blended for repairs. Just takes more time than basic paints.
Apply base, apply mid in stages till color match. Shops will do a draw-down to match difficult colors like pearl white.
Old Jan 25, 2006 | 08:37 PM
wilddog's Avatar
Thanks for the input. I guess my real qestion is the mid layer (the mica). How much to apply. Is there a rule of thumb??
Old Jan 30, 2006 | 03:05 PM
Cowboyfun's Avatar
SoCal STi Hitman
call your local auto paint shop, they should be able to tell you...
