fb upper and lower control arms in rear
Old Jan 19, 2006 | 02:59 PM
mikey D's Avatar
Whats the optimal setup for the upper and lower control arms?
rod ends on the lowers and uppers with super soft bushings?
Old Jan 19, 2006 | 04:33 PM
jgrewe's Avatar
GET OFF MY LAWN
A lot of threads on this subject, you can go the route you're thinking only if you do something to control the top of the rear end, ie. tri-link.
Old Jan 19, 2006 | 06:38 PM
mikey D's Avatar
im planning on a tri link
Didnt know you needed to do the tri link before the control arm mods though.
Old Jan 19, 2006 | 11:25 PM
Kill No Cone's Avatar
The Tri-Link takes on the work of the upper control arms. So, if you go with a Tri-Link you will want to modify the upper control at the same time you install it.
Look at what Jim Susco does at G-fForce or at what Paul Yaw has done with the upper control arms.
Old Jan 20, 2006 | 07:45 AM
Re-Speed.com's Avatar
Optimal setup involves relocating the mounting holes on the rear end housing. Besides going though all that, I would say tri-link it, remove the upper arms, get spherical arms for the lower.
-billy
fjwheeler
22
Jan 9, 2022 01:02 PM
GrossPolluter
Aug 15, 2015 10:32 PM
