Microtech 20b qouestion timing
Old Jan 14, 2006 | 08:34 AM
question about timing
i am doing a little tuning to my 20b only for vacuum and for run in purposes and i saw that my LTX12 has the stock map inside about timing that goes 5 degrees at idle and all the way up to 4000 rpm stays at 9 degrees with 10 degrees split, i search a lot and i find that it is (i think) way to retard.......am i right? should i alter the timing to about 15,20 degrees at vacuum?and with what split? in order to run in my 20b street port with stock twins for now................
Thank you
Dimitris
Sobr609
20B Forum
Feb 11, 2019 03:19 PM
Jan 11, 2016 04:08 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
20B Forum
Aug 18, 2015 02:46 PM
