(IGNITION) 2GCDFIS diagram. Is this correct?
Old Jan 10, 2006 | 05:49 PM
Kim's FB's Avatar
WWW.SUPERCHARGED-RX7.COM
Here's a diagram of how I think it should all be hooked up as. Is this correct? Sorry about the crappy generic paint work, but it makes its point.
All the write ups and pics are great, but I love diagrams.
Should I leave the 2g igniter and wires intact for when the TT becomes available?. Can't wait.
Thanks
Old Jan 10, 2006 | 09:47 PM
inuissus_cendi's Avatar
yeah it looks correct. and you cant really leave the wires intact, as you have to cut them off the ignitor. keep the ignitor though and you can solder new wires to it if/when you get the TT setup.
Old Jan 10, 2006 | 10:17 PM
Kim's FB's Avatar
Cool! Also a big Thanks to you for posting that write up on it.
Old Jan 10, 2006 | 11:05 PM
Kim's FB's Avatar
Hmm? What if I wanted to hook up a MSD 6a to the 2GCDF and eliminate the stock igniter? Could I do it like it shows here on my diagram? If so, do I just remove the stock igniter and use the wires that where attached to it?
Sorry if this has been asked before. I did do alot of searches and there's just tons of ways that people are doing it and it's kind of confusing.
Attached Thumbnails (IGNITION) 2GCDFIS diagram. Is this correct?-msd-hook-up.jpg
Old Jan 10, 2006 | 11:55 PM
gsl-se addict's Avatar
Super Moderator
Actually, you don't have to cut the wires for the regular 2GCDFIS. You only need to remove one of the wires from either the + or - post. It depends because Mazda used two different ways of wiring the balast resistor. I can write something later today to show. That way you can use the TT later. I currently have the TT kits for sale. They will be listed for about 1 month. I will list the assembled ones probably today sometime.
http://www.rotaryx.com/index.php?a=1002&b=249
Old Jan 11, 2006 | 07:02 AM
Siraniko's Avatar
RX for fun
msd 6a/6al to FC coil is easy. ALL YOU NEED IS THE COIL AND BE SURE TO CUT ALL WIRES FROM COIL TO IGNITER; OR YOU WILL BURN THE MSD BOX. Well, keep the igniter too due to the moutning bracket. Just connect the MSD's thin orange and black wires to the coill.
Old Jan 11, 2006 | 07:48 AM
t_g_farrell's Avatar
Waffles - hmmm good
I second the "don't cut the wires" approach. You never know when you might need to switch them around. This also goes for the existing wiring harness leads to the stock ignition. Keep them intact so you can always go back to stock in an emergency (like, say your 2G coil fails for instance). With no tools or just a screw driver you should be able to get the stock ignition wired back up and running in a pinch. You''l thank yourself later.
Old Jan 11, 2006 | 08:49 AM
??? Not sure I understand your reasoning. The way I did it (cutting the wires off the FC ignitor) you can easily switch back to stock too. It doesnt make a difference that way, just so you could upgrade to the Transistor Trick (which uses the FC ignitor) later. I have mine setup so I can switch back to the stock coil in a matter of seconds, I even put in spade connectors so I dont have to take off any bolts, just pull and plug.
GSL-SE addict would probably know better than me. I guess I didnt think of it that way...
Hey Kim's FB, do you mind if I put your diagram in my writeup? Might help lessen the confusion.
Old Jan 11, 2006 | 02:19 PM
Super Moderator
How to: 2GCDFIS without removing 2nd gen ignitor
Okay, guys. Here is how to do the regular 2GCDFIS without removing the 2nd gen ignitor. I recommend doing it this way so you can:
1. upgrade to TT later
2. be able to resell the 2nd gen coil if you sell car, go back to stock, etc.
First, you will need to remove the four screws from the back of the coil pack to take off the back cover. You will need to inspect how the balast resistor is wired into the circuit. Mazda wired it on the - side of the coil on some years and on the + side during other years. It does not matter which side the resistor is on. It just needs to be in the circuit to limit the current load on the J-109.
1. If the resistor is on the + side:
In this case, the resistor is wired on the + side of the circuit. You will notice a tan wire comes in from the top of the coil, goes through the balast resistor, then goes to the coil +.
In this case:
1. remove the black wire from - terminal of coil
2. connect - terminal wire from the stock leading coil to the - on the 2nd gen coil
3. connect 12v switched to the tan wire coming out of the top of the coil. You may need to cut the white connector or find a mating end.
2. If the resistor is on the - side:
In this case, the resistor is wired on the - side of the circuit. You will notice a black wire comes in from the top of the coil, connects to 2nd gen ignitor, goes through the balast resistor, then goes to the coil -.
In this case:
1. remove the tan wire from + terminal of coil
2. connect 12v switched to coil +
or
1b. leave tan wire in place
2b. connect 12v switched to the tan wire that come out of the top of the coil
3. connect - terminal wire from the stock leading coil to the little black wire coming out of the top of the 2nd gen coil
Hope this makes sense. This will let you try the 2GCDFIS while making it easy to upgrade to TT or something else in the future.
Kent
Attached Thumbnails (IGNITION) 2GCDFIS diagram. Is this correct?-with_ignitor.jpg
Old Jan 11, 2006 | 05:16 PM
Unsupa's Avatar
Blew my 3rd one 12/8/08
well i've been running without the resistor ever since i did the normal 2GC.. haven't had a prob, actually my car wouldn't even crank with the resistor in line, so i didn't use it and have been fine.
Old Jan 11, 2006 | 05:17 PM
vipernicus42's Avatar
Rotoholic Moderookie
Dude, this is slated for instant archiving!
Kim's FB, did you make those diagrams? They're very clear, you rock. You should make a Transistor Trick Box one Though I don't know if there are different versions of the TT box that get wired differently.
Jon
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
