Haltech Halwin Base Rotary Ignition Map
Old Jan 5, 2006 | 12:28 PM
Rex4Life's Avatar
RX-7 Alumni
How good is the baseline ignition map that comes with the Halwin software? If you've used it pls let me know what you thought.
I'd like to have something descent to get me around town.
TIA,
Scott
Old Jan 5, 2006 | 06:59 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Is this an E8/E11/E6X map? as i understand it, the only base map from haltech comes with the E11/E8 software.
Old Jan 5, 2006 | 09:04 PM
Rex4Life's Avatar
RX-7 Alumni
It's Halwin V1.59 which I believe is for an E11 or E6X.
When you install the software it creates a baseMaps/STD directory and in there is a 2-rotor.map file.
Old Jan 5, 2006 | 09:15 PM
RETed's Avatar
It's just barely enough to get the car running.
Properly tuned, the ignition map is radically different.
There is a reason why it's called a "base map".
-Ted
Old Jan 7, 2006 | 12:55 AM
EFI Tech Wannabe
Please confirm what system you have, is it an E6X or an E11, totally different installation files, totally different map files. Either way, totally BASE MAP!
Old Jan 9, 2006 | 07:30 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
halwin 1.59 came with my e8.
Old Jan 10, 2006 | 05:44 AM
RETed's Avatar
Halwin 1.62 is available from http://www.haltech.com/
-Ted
Old Jan 10, 2006 | 06:25 AM
opened the box on another e8 last night and it had 1.62
1.62 lets you select between the 8 and 11
Old Jan 10, 2006 | 12:28 PM
EFI Tech Wannabe
In any case, i wouldnt trust one of those base maps, i would rather get one that was worked on a real world application.
Old Jan 10, 2006 | 12:53 PM
i wouldn't trust it to make any power, but i don't think you're gonna blow anything up with a basemap like this one.
Old Jan 11, 2006 | 12:24 AM
EFI Tech Wannabe
Purdy!
Old Jan 11, 2006 | 12:34 AM
RETed's Avatar
Watch it.
We just got an E8 up and running this past weekend, and his order with his E8 came with a disc printed with "1.62" on it.
When we look at what was on the disc, it was NOT 1.62! :P
We had to download 1.62 from the Haltech site.
I think Haltech mislabeled a BUNCH of the CD's by mistake!
So I highly suggest to confirm what's on the CD first!
Actually, when you connect, it auto senses what ECU it's connected to.
You don't need to manual select anything, unless you want to play with it in OFFLINE mode.
-Ted
Old Jan 11, 2006 | 08:30 AM
i'm pretty sure it was 1.62
Old Jan 11, 2006 | 10:06 AM
EFI Tech Wannabe
Man, will you look at that! only 5 bars for vacuum?! yikes! Thats the 7bar sensor right? The 5 bar also has like 7 bars for vaccum, i honestly think that is WAY! too coarse.
Old Jan 11, 2006 | 11:34 AM
oh i dunno. i just loaded up whatever base map was in the std file.
but if you're boosting 7 bar, something tells me you're probably not gonna be cruising around town under vacuum a whole lot.
Old Jan 11, 2006 | 06:42 PM
eViLRotor's Avatar
Brother of the Rotary
Haha, trueDAT.
Looks like even the Halwin for the newer EMS's still can't display vacuum in correct units....
Old Jan 11, 2006 | 10:06 PM
ok, ok... i set it for a 3 bar sensor.
this is what it will look like for most guys when they set up.
Old Jan 11, 2006 | 10:07 PM
i hate how it does vacuum in psi instead of "hg.
Old Jan 11, 2006 | 10:33 PM
Rex4Life's Avatar
RX-7 Alumni
So the base map is set for a 3 bar sensor--looks better now.
Old Jan 12, 2006 | 08:28 AM
the base map just looks like that. you can set it for any sensor you want.
Claudio RX-7
Haltech Forum
Apr 23, 2019 02:50 PM
C. Ludwig
Jan 30, 2019 06:31 AM
Skeese
65
Mar 28, 2017 03:30 PM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
20B Forum
Aug 19, 2015 01:47 PM
