Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
Your going to hate me; but 9000rpm?!
Old Jan 4, 2006 | 03:48 AM
OC_'s Avatar
OC_
I'm bastardizing my car!
So I cut up a perfectly good 60,000 mile 1990 S5...
Well, 160hp wasnt cutting it anymore and I came across this engine for a heck of a deal. Its now totally mounted in the car (in these pics its not). The engine seems a lot lighter then the stock 13b. The car still has its stock suspension and the engine/trans does not have enough weight to bring the car to the proper ride height. This project is nowhere near complete, i still have to do all the wiring and do a lot of finishing work to make things pretty.
I cant wait to try this 6 speed trans out!! My old trans was soooo sloppy!
Next steps after finishing the install:
roll cage
suspension
I will find the weight of the car when this is finished, but progress is going somewhat slow since I'm a full time student.
Does anyone know the weight of a longblock 13b N/A?
Attached Thumbnails Your going to hate me; but 9000rpm?!-dsc02868sm.jpg   Your going to hate me; but 9000rpm?!-dsc02873sm.jpg
Old Jan 4, 2006 | 03:55 AM
DragonRx7's Avatar
Goes *round*round*round*
You're def. going to get flamed for this. 1) For cutting a 60k car up, 2)Putting a Honda engine in it.
I'm interested to see how this plays out (performance wise) but, I can pretty much guarentee you that this'll be moved to Other Engine Conversions
Old Jan 4, 2006 | 04:00 AM
BOOSTED Vert
not bad.... good luck with the conversion.... But if you are not going turbo then there really was no point for the motor swap.... W.e. good luck...
Old Jan 4, 2006 | 04:01 AM
OC_'s Avatar
OC_
I do have my regrets. But the engine was such a deal! cheaper then a turbo swap!
Old Jan 4, 2006 | 04:07 AM
BOOSTED Vert
you shoulda sold the motor and made some good profit... They sell for about 6k...
Btw.. what are you gunna do about the computer ?
Old Jan 4, 2006 | 04:38 AM
SonicRaT's Avatar
Super Raterhater
And slower
Old Jan 4, 2006 | 05:56 AM
RETed's Avatar
Uh, it's been done already...
-Ted
Old Jan 4, 2006 | 06:38 AM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
if I was gonna do a piston motor swap it would have to be a rb series motor. dunno if it will fit though. heres how much a 13b wieghs=light enough for me to pick up in long block.
Old Jan 4, 2006 | 06:58 AM
SureShot's Avatar
Seduced by the DARK SIDE
We don't hate you. - We fell sorry for you.
You are helping to increase the value of our rotary cars.
Old Jan 4, 2006 | 10:30 AM
CyborgRyu's Avatar
Drift FC
hooooooomooooo
Old Jan 4, 2006 | 10:38 AM
SirCygnus's Avatar
whats going on?
i woulda swapped a volvo motor in.
Old Jan 4, 2006 | 10:44 AM
classicauto's Avatar
Crash Auto?Fix Auto.
that would be one hell of a clean and jerk..........you must be tougher than these 6 year olds....hehehe
I don't know what a 13b would weigh with all the accessories and manifolds bolted up......maybe 500 pounds? beats me...why don't you just weigh the motor you pulled out - its out - get a scale.
Old Jan 4, 2006 | 11:08 AM
DREYKO's Avatar
I "lost" my emissions....
i really feel bad for the car... was there anything wrong with the old engine? why'd you swap em? i still dont see much point. ah well if you dont need the engine give it to me. ill bring it back to the road.
Old Jan 4, 2006 | 12:22 PM
RotaryEvolution's Avatar
Sharp Claws
or a V8, but whatever floats your boat.
Old Jan 4, 2006 | 03:16 PM
owen is fat's Avatar
man I cant believe you had to cut the firewall so much!
theres an f20c powered FC in Hawaii, sweet!
Old Jan 4, 2006 | 03:33 PM
GodSquadMandrake's Avatar
Radioactive Rotary Rocket
I like this more than a V8. I'm actually interested to see how it goes. So is this an RSX engine? Any details on your plans or what transmission you are using?
As far as the weight of an S5 longblock I would say it has to be 350-500 pounds with transmission and everything bolted to it. My S4 engine was so heavy that it took 3 guys to lift it and we were straining. I was really baffled by this because everyone talks about how light a rotary is and i'm like NO IT'S NOT.
Old Jan 4, 2006 | 03:39 PM
gnx7's Avatar
Should be a fun conversion... S2000 motors may put out 240hp... but they have essentially no torque just like an n/a 13B.
You should think about turboing it if there is room. If the exhaust manifold is on the passenger side there should be plenty of room.
Good luck... sounds like a unique project.
Old Jan 4, 2006 | 04:48 PM
Snrub's Avatar
http://www.geocities.com/jeffguilfoi...neweights.html
A S2K engine weighs a little more than a S4 13B. 348lbs vs. 337lbs.
Old Jan 4, 2006 | 05:00 PM
Turbo II-FB's Avatar
its actually harder to turbo the s2k motor. Its to High compression. Most ppl Super charge or pro charge them. I think its a intresting idea good luck and get us some vids of it running
Old Jan 4, 2006 | 05:03 PM
This should probably be added:
*Note: All engine weights are fully dressed wet weights. So for instance, the full S5 drivetrain would include ABS pump, power steering, air pump, air conditioning and alternator.
But I am wondering if this includes the transmission because that could make quite a bit of difference. Are you sure the Honda engine is lighter?
Interestingly enough the Renesis engine weighs only 276 pounds, which is 100 pounds lighter than the S4 N/A engine!
Old Jan 4, 2006 | 06:20 PM
Project88Turbo's Avatar
Stock boost FTW!
That could possible be attributed to the plastic intake and lack of engine driven P/S pump + brackets.
Back to the thread though: What you doing for engine management? I think the S2K engine is an interesting swap, although the firewall modifications do not look fun.
Vince
Old Jan 4, 2006 | 09:48 PM
DiverseCC's Avatar
i just feel bad for the car, and using a honda motor, i dont even know what to say, my cuz has an S2000 and i can whoop on it all day in my RX with it tuned down running almost no boost, even if it would be fast or whatever, it wouldnt be worth it to me
Old Jan 5, 2006 | 03:39 AM
Chi_San's Avatar
Turbo Fanatic
Or a twin turbo V6, which makes way more power than a V8.
Or even a H6, porsche FTW. Lighter, more power, and lower than either a V8 or I4.
Old Jan 5, 2006 | 06:01 AM
Play Well
I should wiegh it if i wasnt strewn across the country. The only things that werent on it were the PS/AC and exhaust manifold. Lifting up out of the engine bay was easy putting it down on the ground was the hard part.
To lift it up out of the bay I just took off the hood and stood on the fenders put a jack on the oil pan to slide it forward off of the tranny and just lifted with my legs. then placed it gently on the drivers fender and after about dropping it on the ground called my friend who helped me put it on the ground then carried inside and down into the basement for disasembally.
Its all in the legs. Basically if I can get a grip on it and lift with my legs I can lift some big stuff. I have maxed out every wieght machine for your legs at mautalis with one leg. I guess thats what I get for being in the marching band and on the track team.
Old Jan 5, 2006 | 08:51 AM
Crash Test Joey's Avatar
Zero Rotor Motorsports
Haven't seen many daily driver rotaries on the auction block at Barrett Jackson. I wouldn't go getting collector car insurance just yet. What's your car worth? $3k or so?
