FD Throttle body
Old Jan 30, 2002 | 06:14 AM
flying taco's Avatar
Rock Star.... almost
FD Throttle body
What's up guys?? I have already did a search on the throttle body mod and found one post, and the thread within that post no longer works, so I'm curious: What all do i need to do to upgrade to an FD throttle body?
Thanks
Aaron
Old Jan 30, 2002 | 10:48 AM
Erik's Avatar
Best of both worlds
soul assassin has it......there is a company in japan called Garaga Vanna that i think places the bolts different so its possible to bolt on...
Old Jan 30, 2002 | 11:09 AM
Turblown's Avatar
Turn up the boost
cool, i was going to do it but there is a lot involved... but if its bolt on in all why the hell not....
Old Jan 30, 2002 | 11:49 AM
neofreak's Avatar
accept no imitations™
Because you need a FMIC, and most people here are too cheap to go that route. =p
There is a kit coming to take care of this, however. =)
Old Jan 30, 2002 | 11:53 AM
So without that kit it's pretty though then eh??
Aaron
Old Jan 30, 2002 | 12:08 PM
neofreak's Avatar
I test fitted the adaptor, it works great, and makes it increadibly easy, but since I'm not ready for my FMIC (still got my turbo waiting for rebuild/upgrade) I didn't install it. I'll call them to see if they plan on marketing this if you're interested, they thought it wouldn't be worth the effort of producing them. (not due to lack of performance, but lack of interest)
Old Jan 30, 2002 | 12:11 PM
SpeedRacer's Avatar
Formula Mazda Driver
Whats so special about the FD TB? Does it flow that much better?
Old Jan 30, 2002 | 12:20 PM
cymfc3s's Avatar
I Raise Chickens
Its supposed to be good for around 20HP. I think the biggest restriction on the FC intake track is the throttle body elbow.
Old Jan 30, 2002 | 09:40 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
HERE's an idea for you. (Thanks CHRIS! RP ROCKS!)
Use an NA intake elbow if you go with a FMIC. It fits, it's not restrictive like the stock TII one, and it's cheap and readily available. It's NOT pretty, but it works.
Old Jan 30, 2002 | 09:47 PM
NZConvertible's Avatar
I'm a boost creep...
Yeah, but it's made out of 15 year old Mazda plastic. How much boost/heat is it going to take before it ***** itself?
Old Jan 30, 2002 | 09:55 PM
Originally posted by NZConvertible
......before it ***** itself?
LOL I'm tired and that amused me....
Old May 28, 2003 | 01:03 AM
Bringing this one back from the dead... So, since I want to hook up a FMIC this summer and don't want to get the whole Greddy Kit and don't want to use the NA elbow, an adaptor plate between the FD UIM and FC LIM is what i need right?? One of my friends works at a place where I can have one machined... how difficult of a pattern would this be?? All it has to do is match up the two differing bolt patterns right? Do you think doing the FD TB upgrade and all this stuff will be worth it (money/benefits), or should I just giving in and buy the Greddy kit?
Thanks
Aaron
Old May 28, 2003 | 03:02 AM
Read this thread on putting an FD UIM onto a S5 LIM. I understand the S4 LIM doesn't work quite as nicely.
Wait, did you mean the the UIM and TB or just the TB? I've never seen anyone put the FD TB onto an FC UIM, but with some enlarging of the plenum's secondary ports and an adaptor plate it might work. It's only about 15% bigger, so I wouldn't expect a huge gain, maybe 5% peak depending on your mods.
BTW, since I posted that comment above I've heard of a couple of people successfully using NA TB elbows on turbos, and havn't heard anyone complain of them "shitting themselves", so maybe they're stronger that I thought. Might be an easier and cheaper option to consider.
EDIT: Just noticed you did mean the whole FD UIM. Oh well, something to think about.
Old May 29, 2003 | 04:35 PM
RETed's Avatar
I doubt it makes any serious power advantage over the stock TB.
The conversion is a royal pain in the ***.&nbsp Rewelding on cast aluminum is not an easy job.&nbsp The stock oil filler neck does not fit, especially if you're using the GReddy elbow.&nbsp Running it through the stock power steering is almost impossible, especially using the GReddy elbow.
-Ted
Steelwheelz
Sep 15, 2015 03:22 PM
