HKS vs XS cast manifold...
Old Jan 30, 2002 | 03:37 AM
spigot's Avatar
Ok can anyone tell me what the difference is between the two (except the HKS being $100 more?) Does anyone have pictures of the two?
Thanks,
Matt
Old Jan 30, 2002 | 07:39 AM
FD_Pilot's Avatar
Pic of my T04S kit is here....
http://www.fdpilot.com/t04s/kit.html
Old Jan 30, 2002 | 12:51 PM
carcrazy's Avatar
Pics of my HKS kit are on my WWW icon.
I heard the X S Engineering manifold is the best - too bad I purchased before knowing this.
regards
Rick
1993 RX-7
Old Jan 30, 2002 | 01:44 PM
1FastT2's Avatar
Can you buy the XS engineering manifold seperately? If you can, from where and how much?
Old Jan 30, 2002 | 03:38 PM
FD_Pilot's Avatar
xs-engineering.com has them on their website...
use their search tool... drop down menu 93-95 RX-7.... search word "manifold"...
$552.17
Old Jan 30, 2002 | 04:26 PM
Jason's Avatar
The one
I sell the XS manifold at the RX7 Store. It is on a month backorder right now. Its almost identical to the HKS cast manifold, but a cheaper.
Jason
Old Jan 30, 2002 | 05:40 PM
spigot's Avatar
Thanks everyone, I figured there wouldn't be much difference between the two.
Matt
Old Jan 30, 2002 | 08:21 PM
Marshall's Avatar
I get a boner ever time I look at my SFP manifold. I think they're like $475....very nice stuff.
Old Jan 30, 2002 | 10:52 PM
stevecod's Avatar
can you post some pictures of the sfp maifold?? i'm about to get one from them but don't know what it looks like.
thanks, steve
Old Feb 2, 2002 | 02:19 PM
Otay's Avatar
Blah, Blah, blah
Someone please tell me about this SFP manifold???
Old Feb 2, 2002 | 05:09 PM
Poweraxel's Avatar
Re: HKS vs XS cast manifold...
as i said before the greddy T-78 manifold is the best out there IMO...divided equal length runners..S.S. ..greats welds..T04 split flange
no doubt about it
Old Feb 5, 2002 | 12:23 AM
Jetlag's Avatar
I seems to me that the XS manifold has a tiny wastegate runners. How big are the runners anyways? .75-1"?
Wouldn't that cause boost creep?
Old Feb 5, 2002 | 01:28 AM
vosko's Avatar
Just Call Me Terminator!
Re: Re: HKS vs XS cast manifold...
Originally posted by Poweraxel
as i said before the breddy T-78 manifold is the best out there IMO...divided equal length runners..S.S. ..greats welds..T04 split flange
no doubt about it
purdy ain't it
Old Feb 6, 2002 | 08:19 AM
Kurgan's Avatar
Gaijin Racing
no doubt about it
Can you just purchase this manifold seperately? If so, can someone give a quote on it?
Old Feb 8, 2002 | 05:47 PM
fast13b's Avatar
Looking for a S5 TII??
I just received my (fc) XS cast manifold. While it is an AWESOME unit, I have a particularly large tangental T04s and it wont fit on because the housing butts into the intake runners. A normal turbo should fit no problem... Just for everyones information.
Old Feb 10, 2002 | 02:52 PM
XSPOWER's Avatar
The XS cast manifold does not share any similarities to the HKS cast manifold. The wastegate runners are 1.3" each and quickly combine into a 1.9" runner. One special feature of the XS manifold is where the manifold bolts to the engine. The ports leading into the manifold are the same size as the gasket (approximately 2.375") whereas all other exhaust manifolds are only about 2" or 50mm. Each port gently merges into the size of a divided inlet T04. We've found this manifold design to make more torque and hp and that's why the manifold is designed like that. This is the advantage of our cast ex. manifold because this design would be very time consuming ($$$) to produce in a tubular manifold. I would post pics, but I don't have them on this computer.
The Greddy manifolds are beautiful pieces. I use a Greddy manifold on my Supra too. It is a piece of art. But at $1800 retail (greddy) vs. $552 retail (XS) you can clearly see the advantage.
Old Feb 25, 2002 | 12:43 AM
Has anyone used this xs engineering manifold with a TO4E in a FC? Any clearance problems, especially with the intake manifold?
C
Old Feb 25, 2002 | 12:52 AM
Poweraxel's Avatar
I agree
Old Feb 25, 2002 | 03:00 PM
RETed's Avatar
See other thread. Get the Racing Beat 13B flange for a spacer for a cheap fix...
-Ted
Old Feb 25, 2002 | 03:05 PM
RETed's Avatar
Is this official word from XS Engineering?
Bullshit! I've had the XS Engineering cast divided turbo manifold (1st production run) side-by-side with an HKS divided cast manifold.&nbsp You know what - the resemblance is striking!&nbsp Exhaust paths are identical in location and even the wastegate mounting angle is similar - hell doesn't the XS manifold USE an HKS wastegate flange bolt pattern?&nbsp The XS Engineering manifold DOES have larger ports - this is obvious.
I think someone from XS got the HKS manifold and told the cast factory to build a slight bigger version with larger ports on it.
This is for the initial 1st production run for the XS Engineering manifolds, so if the design was change, this blows all my arguments out of the water.
-Ted
Old Feb 25, 2002 | 06:33 PM
XSPOWER's Avatar
Just because something looks similar, does that mean it's the same? Is a Mustang with a 3.8L V-6 anything close to a Mustang Cobra?
The flange positions of the XS manifolds are all different than that of the HKS manifold. It was designed in-house and it is quite different. Check it out again and I'm sure you'll find that there are significant differences.
Old Mar 4, 2002 | 05:13 PM
Can i use any of these on my UK car?
I have a the Steering wheel on the other side so the wastgate will foul the Steering rack? any idears?
Old Mar 5, 2002 | 08:08 AM
1point3liter's Avatar
Twin Turbo LSX
Is there a possibilty of the Tial 46mm wastegate fitting on the XS manifold?
Old Mar 5, 2002 | 10:08 AM
surfpac's Avatar
Jason,
The RX7store website doesn't have any links to the manifold. Maybe I'm doing soemthing wrong?
Old Mar 5, 2002 | 10:41 PM
fast13b's Avatar
Despite the IMMENSE HEADACHE acquiring and installing the XS unit on my FC gave me, I would still recommend it over the HKS because it is a god damn TANK if for no other reason (like the superior port sizes...) That thing will outlast the car, and coming from a cracked steel manifold I'm all about that...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
