oil plug
Old Dec 28, 2005 | 03:50 PM
krishant's Avatar
Ex-Rotorhead
oil plug
i just changed the oil on my vert, and while i was at it i installed a new oil plug and metal crush gasket.... i have the plug tight, but i believe it is still leaking? I dont know what the problem might be....only reason i changed the plug was because somewhere along the line before i started changing the oil myself the oil plug was rounded and would only come off with 12point wrench....i picked up the new plug at autozone with a gasket...the threads appear the same and the head size went from 19 to 18mm from the orginal to the new one....i believe the other plug may have been the original... i dont know why it wont form a good seal...
Old Dec 28, 2005 | 03:59 PM
The Wankler's Avatar
FKITALL
You can always get another one from Mazdatrix and see if it leaks.
Old Dec 28, 2005 | 04:01 PM
classicauto's Avatar
Crash Auto?Fix Auto.
you "believe" its still leaking.....is it leaking or not?
it may be burs on the seating surface of the oil pan (if its leaking at the plug)
but tell us if it is ACTUALLY still leaking first
Old Dec 28, 2005 | 05:13 PM
krishant's Avatar
Ex-Rotorhead
the plug is leaking
Old Dec 29, 2005 | 11:57 AM
krishant's Avatar
Ex-Rotorhead
i believe the aftermarket oil plug is leaking??? has anyone else had this problem?
Old Mar 16, 2006 | 05:29 PM
krishant's Avatar
Ex-Rotorhead
ok i changed my oil again, and i reinstalled my original plug thats been slightly rounded off, it goes in perfectly fine and can be tightened and loosen with a 12point closed wrench... I compared it with the aftermarket original plug and the thread are longer on the original plug... where can i get a new oem oil plug for my FC? will dealerships have this item or would that be impossible?
Old Mar 16, 2006 | 06:49 PM
Go48's Avatar
See a dealership parts department. If they don't have it on hand they will order one.
Old Mar 16, 2006 | 07:23 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
you say gasket? is it a gasket or a copper crush washer?
Old Mar 16, 2006 | 08:26 PM
The Flash's Avatar
I agree. They may have to order it, but go with the "real deal".
The1Sun
Mar 18, 2018 11:08 PM
Snoopy FD
Dec 8, 2015 01:45 PM
alphawolff
Nov 17, 2015 05:57 PM
rocker1337
16
Sep 6, 2015 11:28 PM
