engine year
Old Dec 28, 2005 | 09:01 AM
kjs86rx7's Avatar
engine year
is there a way i can tell what year the engine in my 86 is i dont think it is an 86 thanks for your respose
Old Dec 28, 2005 | 09:17 AM
banzaitoyota's Avatar
What Subscription?
OMP Style
Intake Manifold
Old Dec 28, 2005 | 09:22 AM
classicauto's Avatar
Crash Auto?Fix Auto.
^^^meaning....
Electric MOP - S5
Mechanical MOP - S4
as for Intakes, search for pics of S4's and S5's - itll be easier than describing it
Old Dec 28, 2005 | 05:36 PM
kjs86rx7's Avatar
whats an mop? thanks for your knowledge
Old Dec 28, 2005 | 05:45 PM
Project84's Avatar
Open up! Search Warrant!
The rotary engine mixes oil with the air/fuel mixture at a rate of 1quart of oil per every 1000 gallons of fuel consumed. OMP (Oil Metering Pump) or MOP (Metering Oil Pump- as designated by Mazda) are both refering to the oil metering pump. It is a small oil pump attached to the front cover of the engine and it pumps oil through small tubes to the 4 oil injectors on the engine. The pump is shaft driven and the amount of oil to be metered in is based on throttle position (either mechanical linkage for the 86-88 engines, or electrical signal for the 89-92 engines.) The shaft driving the pump is geared to the front of the crankshaft.
Old Dec 28, 2005 | 05:48 PM
matts86fc3s's Avatar
southern style
Oil Metering Pump... on front of front cover of engine below water pump... youll see 4 plastic (probly tannish faded) clear lines running up the front off to the left side. if it is an electric style then youll see wires coming from it. but since yours is an 86, and unless they switched the wiring harness from an s5, you probly will not have any clue of finding year of motor, and electric omp will not work on s4, so either way they had to put a mechanical one on there. doesnt really matter anyhow theres not much hp difference if thats what your trying to find out... maybe a 15 -20 hp difference thats not much
Th0m4s
Feb 26, 2019 02:04 AM
alphawolff
Nov 17, 2015 05:57 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
