FB transmission in FC
Old Dec 27, 2005 | 03:04 PM
bigdaddyp's Avatar
Hi, I was wondering if a transmission out of a 5 speed fb will fit into my 5 speed fc? I have an 85 gs with a good transmission and my fc's transmission is going out. Will it work, if it needs moddified, what will it take? I did a search, but was mostly FC into FB. Thanks in advance.
Old Dec 27, 2005 | 03:24 PM
Aaron Cake's Avatar
Engine, Not Motor
Starter, driveshaft, clutch, flywheel, slave cylinder and mounts are different, as well as the shifter location. Also electrical.
So it's not a bolt in by any means.
But if you swap the flywheel from the 12A (balance issues? I don't know the weight of it compared to the 2nd gen flywheel) and clutch, the transmission will bolt to the engine. The rest is up to you.
Old Dec 27, 2005 | 11:18 PM
unek87's Avatar
NA-BOOSTIN
when i did it i had no problem bolting one up to my fc. the only thing is that it set up a inch or 2 in the shifter so i had to cut some platsic were the shift boot hold against . but then after a few week i just swapped the tail shaft off of my fc tranny and bolt it up to the fb and then ever thing bolted up and sat right . the only thing that suck after word is that your 5k in 5th the hole time and it sucks up your gas
Old Dec 28, 2005 | 01:08 AM
KeloidJonesJr.'s Avatar
strictly business
How is the 5th gear in the FB? Does it grind when you shift into it?
Old Dec 28, 2005 | 01:14 AM
Liquid Anarchy's Avatar
We come with the Hardcore
...I was under the impression that the tailshafts of all the non-turbo trannys could be bolted up to one another...
Old Dec 28, 2005 | 01:40 AM
unek87's Avatar
NA-BOOSTIN
i believe they can be . 5th never grinded for me . the tranny was great off the line but as far as top end goes its a lil on the sad side aleast for the fc .
Old Dec 28, 2005 | 08:32 AM
bigdaddyp's Avatar
no the one I have doesnt grind.
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
