problem with my 89 gtu na, need help please!!
Old Dec 27, 2005 | 02:33 AM
dailong's Avatar
hey guys, i need your help. my 89 gtu na keeps producing an error code for the CAS. I think that because of that my timing won't advance. its actually retarding. I had the fuel injectors sent in to be cleaned and flow tested, ecu refurbished, new tps, and 4 different CAS were tried on it but it still hasn't fixed the problem. we are going to switch out the engine wiring harness today and see how that goes. I checked for vacuum leaks but there isnt any. At least me and the mechanic can't find any. does anyone have any ideas what might be wrong?? i appreciate all the help i can get. thanks.
Old Dec 27, 2005 | 02:43 AM
dothacker's Avatar
reset the ecu? ever tried that one? like taking the negative wire from the battery for at least 5 seconds?
Old Dec 27, 2005 | 10:11 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the CAS plug where the engine harness joins the body harness on the spark plug side. Clean and repack with dielectric grease.
Old Dec 27, 2005 | 12:27 PM
SureShot's Avatar
Seduced by the DARK SIDE
^^ Aaron's tip is the best bet.
Also route the spark plug wires away from the CAS wires.
Also check the small square black filter capacitor that mounts on the clutch slave.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
