I wanna see FLAMESSSSSSs!
Old Jan 29, 2002 | 04:38 PM
Street King's Avatar
*** Bless Texas!
I want to see flames but i don't want to get a mid-pipe because the unstability of boost spiking. I have a profec b but i heard its still real hard to control with a mid-pipe. Could I get a high flow cat and what else would I need to shoot the flamage.
Thanks
Hey don't flame me about wanting to see flames shoot out my exhuast just for looks. You know you want that too!
Old Jan 29, 2002 | 04:45 PM
2FAST7S's Avatar
I dont think you can do that any other way than by using a mid pipe.
Sorry
Old Jan 29, 2002 | 04:46 PM
DK's Avatar
DK
40k worth of fail
You can't really do it with a cat in there, period. Now I don't know what exactly makes a high-flow cat a high-flow cat, but I'm still guessing that all exhaust passes through and is screened in the cat. This would prevent flames from passing through. If it would allow flames, it would be very minimal ... but since I don't know the details of high-flow cats I don't want to rule it out.
So you can be ghetto and do the sparkplug thing behind the cat and see if you can ignite the exhaust after the cat.
Old Jan 29, 2002 | 05:17 PM
RyanREX's Avatar
Killer Turbo Twins
Re: I wanna see FLAMESSSSSSs!
Don't tempt me!
Old Jan 29, 2002 | 05:37 PM
HighTach7's Avatar
3 footer
I shoot some wicked flames. Even shifting moderately at 4-5,000 RPMs it can throw out a decent flame. The flames have brought me fame in my city har har
Anyways this is my setup, its relatively cheap:
Intake
Full 3" exhaust with Apexi N1 single (good luck on flames with a cat)
G-Force ECU, which is programmed fairly rich
street port
I have other mods but i doubt they're related to shooting flames.
Basically a full exhaust and a rich computer will do the trick everytime. It's better to be rich than lean in an RX-7. BE SURE you at least have a boost controller if you install a midpipe.... O yea, and be ready to wear ear-plugs
Old Jan 29, 2002 | 05:45 PM
Sloraxe's Avatar
You can have massive flames shooting out the back for under 10$
Simply drill a small hole towards the end of your exhaust and insert a spark plug, wire it to a switch.
Flip the switch and watch the flames shoot out and cook the car behind you.
I haven't tried this yet, but have read a few places on the theory of getting to work.
Old Jan 29, 2002 | 05:59 PM
rx7speed811's Avatar
Accepting Donations.
you have an rx-7!!!!! do not do the ghetto spark plug thing, that is for incompetent cars like your moms daewoo. you do not have a lame car, you can shoot flames easily if you want to.
if you want to shoot flames, just get full exhaust and run a richer ecu, then rev it high and POP! you have a flame.
oh yeah, and you cant do it with a catalyst in place because it cockblocks your flames.
have fun.
Old Jan 29, 2002 | 06:02 PM
mightyslash's Avatar
Will Work for Ferrari
I have one
Old Jan 29, 2002 | 10:49 PM
Brent Dalton's Avatar
Sua Sponte
I know a guy in knoxville that has the spark plug thing hooked up in his supra. It shoots some hella flames. Flames way bigger then any car can shoot running rich. I've heard he does it when ppl cut him off....he then proceeds to pull in the next lane a little ahead of them, flip the switch, and scare the other driver to death.......the other driver then pulls over and checks their shorts. I wouldn't do it to my car, but I do think it looks cool......plus it's completely controlled. Just my $.02
Memphis
Old Jan 29, 2002 | 11:08 PM
Zoomspeed's Avatar
Not that I'm gonna do this but I was just wondering, how do you "wire up" a spark plug? You can't just slap on a wire, can you?
Old Jan 29, 2002 | 11:47 PM
capt. bill1's Avatar
The plug will be grounded on the exhaust. So you just need to run a wire through a switch to 12 volts.
Old Jan 30, 2002 | 02:15 AM
skunks's Avatar
I'm a CF and poop smith
you also forgot to mention that you need a coil as well, the old muscle car guys use to do this trick except that they could do it easier cuz they actually sell kits for this application. only thing is that their kits are only designed for carbarated (spelling is off) cars. it does pretty much what the motorcycle guys do, it cuts the ignition and then turns it back on, the longer it is shut off, the bigger the flames, this cant work on efi cars though. i was wondering if anyone had a superafc out there and actually tried doing this? oh well good luck
Old Jan 30, 2002 | 03:07 AM
KINETIK_FD3S's Avatar
almost done
anyone with flames, post some pictures!
Old Jan 30, 2002 | 10:28 AM
Coulthard Fan's Avatar
You need to remove the cats. If you are worried about controlling boost put a restrictor plate before the midpipe. Most people say that a plate with a 2.5 inch circular opening is enough to keep boost under control. Do a search on the forum to see how people have don this and what material they used. You are gonna have to make it yourself, but it will probably run you about two bucks plus new gaskets (which should come with the midpipe).
Later,
Scott
Old Jan 30, 2002 | 10:34 AM
1bad7's Avatar
can i install this restrictor plate after the MP. right where the catback attaches? will it be the same?
Old Jan 30, 2002 | 11:10 AM
RyanREX's Avatar
Killer Turbo Twins
Not my car...but a good pic:
Bojmend
Oct 7, 2015 09:32 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
mulcryant
Sep 9, 2015 05:24 PM
86rxNa
Aug 11, 2015 11:51 AM
