Radio cuts in and out? Help
Old Dec 25, 2005 | 06:17 PM
HardHitter's Avatar
Ok, so I picked up my FD with an aftermarket deck and everything works, but when I am listening to the radio, the radio will cut in and out and the signal isn't very strong. Is it the deck or does the car need a new antenna or what do you guys think it is? When I put a CD in the sound and everything is fine. Any way to do some troubleshooting?
Old Dec 26, 2005 | 02:39 AM
HardHitter's Avatar
Bump for help?
Old Dec 26, 2005 | 03:17 PM
BklynRX7's Avatar
King of the Loop
Arrow
Maybe the connection between the antenna and unit is bad.
Old Dec 26, 2005 | 07:06 PM
HardHitter's Avatar
Guy in the audio store told me the FD has two sets of antennas? One of the rear windshield and the other that comes up when you turn the car on? He said it's cutting in and out because usually you only have one antenna plugged in? Is that true? What to do to fix this?
Old Dec 28, 2005 | 08:08 AM
turbo2SE's Avatar
yeah its a rotary
my best guess is remove the whole antena line from the car to see if its damaged anywhere. my fc antena was like that so i ended up replaceing my stock power antena for some power after market antena from advanced auto parts .and when i installed that i could hear the radio again. BTW you might want to also check your grounds the ones on the antenas (thats if its a powered ) antena and on the back of your deck
monty
Aramir
Oct 18, 2015 02:39 AM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
