6th ports
Old Dec 25, 2005 | 05:14 PM
red rex's Avatar
6th ports
alright i know theres been enough of these posts on here but this one is different.
so heres the deal my actuators aren't actuating
my actuators are working along with the sleeves
air is flowing through the lines to the selonoid without a problem and the air pump is working fine.
the selonoid itself is working i tested it and it is actuating.
heres the problem...when i tested the connector that connects to the selonoid there is no electrical signal what so ever no matter what rpm i rev the motor too. and i know that there is a signal sent at a curtain rpm to this selonoid. so am i looking at a burnt out wire somewhere along the line?
also. what sends the signal to the solonoid?....could that be burnt out?
does the signal get sent from reading where the rpm stick is on the tack?
thanks for the help
Old Dec 25, 2005 | 05:45 PM
red rex's Avatar
bump
Old Dec 25, 2005 | 05:56 PM
jono20's Avatar
the solenoid only gets the 12v if the engine is under load. cant just sit there in neutral revvin the engine.
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
josef 91 vert
14
Sep 17, 2015 09:22 PM
