Exhaust question... (The small piping/bar that connected to somewhere in the....
Old Dec 24, 2005 | 07:46 PM
RevUp13b's Avatar
zZzZzZzZzZz..............
Hey guys, i ran into another question... I got all the screws off thanks to you guys to get the manifold off...
anyways, theres this small pipe/bar thingy tahts connected to the Cat and the pipe before the manifold and leads up sumwhere to the engine bay??? what am i supose to do with that pipe/bar thingys.... its like a small pipe thats goes along side of the full exhaust on the passenget side....
Thanks
Old Dec 24, 2005 | 07:54 PM
EJayCe996's Avatar
There were no survivors
Sounds like it is the line from the airpump if it's connected to the cat.
Old Dec 24, 2005 | 08:30 PM
RevUp13b's Avatar
soi what am i supose to do with it if i was to take off the cat??
Old Dec 24, 2005 | 08:35 PM
unek87's Avatar
NA-BOOSTIN
you dont want to do that. thats what makes your 5/6 ports work you can remove the other 2 cats but leave the main or you can buy a test pipe ment to go in oplace of the cat so that they still fuction
Old Dec 24, 2005 | 08:36 PM
EJayCe996's Avatar
Remove the airpump as there would be no point in having it on if you remove the cat. It'll free up ~1-2ish hp and improve engine response a little as well. One less piece of parasitic drag. Assuming you have a series 5 (89+) RX-7
Old Dec 24, 2005 | 08:37 PM
unek87's Avatar
NA-BOOSTIN
or you can do that ^
Old Dec 24, 2005 | 09:17 PM
RevUp13b's Avatar
so what do i do with the hose that comes after the air splitter thingy???
Old Dec 24, 2005 | 09:55 PM
Jager's Avatar
Tear you apart
Thanks
Its called a split air tube, it actuates your 5th and 6th ports. Leave it on unless you remove the system entirely (sleeves and all, total unrestrictive flow) or unless you can jimmy up another way for them to work.
Old Dec 24, 2005 | 09:57 PM
Jager's Avatar
Tear you apart
Removing the air pump on an s5 will **** up the 5th and 6th ports resulting in a failed system, since the 5th and 6th ports are actuated off the ECU by the air pump. My only suggestion then is to wire in an RPM switch.
Old Dec 24, 2005 | 11:02 PM
RevUp13b's Avatar
So for those with RB headers/ Presilencer connected to a catback? What do you do with that tube?
Old Dec 24, 2005 | 11:29 PM
Alex6969's Avatar
The Silver Bullet
cut it off and plug it, its one hell of a vac leak. like posted above wire up an rpm switch to open the port on an s4. mine are just wired open right now, because i have a straight through exhaust and no money or time to wire one up. that will be done shortly
Old Dec 24, 2005 | 11:40 PM
RevUp13b's Avatar
so do i just leave the hose hanging with nothing connected to it???
Old Dec 24, 2005 | 11:49 PM
Alex6969's Avatar
The Silver Bullet
no, you plug the lines, a srew(small line) and a spare socket(big line, it is a 14mm i belive is what i used) it what i used. Prolly not the best way to do or the right way to do it, but hey, its what i had laying around at the time.
Old Dec 25, 2005 | 05:56 AM
RevUp13b's Avatar
What if i have a s5???
I heard the 5th and 6th ports werent related to the air splitter on the S5, as to the S4 pre-silencer has a place for the air splitter i think.... not sure though
thanks everyone
Old Dec 25, 2005 | 02:12 PM
Jager's Avatar
Tear you apart
Is there a little hanger thing coming off the presilencer? If there is, plug it in. If not buy a block off kit off BanzaiToyota and do it legitmately.
Since I know you have a S5 I say block it off. The ECU controls the 5th and 6th ports anyways so as long as you don't remove your air pump, you should be fine.
Old Dec 25, 2005 | 02:16 PM
Jager's Avatar
Tear you apart
That's a terrible solution. It takes just a day and maybe $15 bucks to get them running correctly. Wiring them open has a loss of low end, torque curve, and with a very little gain on the top end.
If you don't want to use them, remove them completely (sleeves also) and block it off (giving it unrestrictive air flow in the engine).
Old Dec 25, 2005 | 04:20 PM
Alex6969's Avatar
The Silver Bullet
I'm not saying that that is the final solution. i just did that for the time being and focused on the other problems of the car. what do i do with the lines if i want to get the ports working again?
Old Dec 25, 2005 | 04:37 PM
Go48's Avatar
I believe that the RB presilencer has an attachment point for the air pipe. At least on my S5, the air pipe is connected to an RB presilencer. (Former owner installed the RB down pipe and presilencer.)
astrum
24
Nov 15, 2017 08:44 AM
andyvideopro
Aug 11, 2015 09:16 PM
