ready to remove acv... i think
Old Dec 24, 2005 | 12:59 AM
MIDNFauciUSN's Avatar
Roll FIS green
well, i think i've read just about every thread on here about acv removal...
a couple of questions:
1. after you pull the acv... do you pull the sleeves too? leave them in there?
2. where can i get the sheet metal for the plate? home depot?
Old Dec 24, 2005 | 01:01 AM
Jager's Avatar
Tear you apart
Sleeves?
Describe what you are removing. TII or NA?
Old Dec 24, 2005 | 01:14 AM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
yes on the sheet metal. i actually used the metal from industrial electrical outlet boxes. worked perfect.
as for the sleeves , i think your thinking of the 5th and 6th ports on a na . if thats the case and you are talking about the sleeves then you have 2 different mods mixed up. but if you pull your acv and you have a s5 then you might have to either wire them open or remove them .
Old Dec 24, 2005 | 01:15 AM
RotaryEvolution's Avatar
Sharp Claws
im going out on a limb and say its n/a since there is no sleeves in a T2. it will be kinda tough to find a sheet the right size for the ACV block off unless you find a local sheet metal shop. you can simply wire open the port actuator arms rather than taking the intake off and removing the sleeves.
Old Dec 24, 2005 | 01:51 AM
Alex6969's Avatar
The Silver Bullet
they make block off plates, i thought mazdatrix has them. its been a while since i got mine. If you have an s4 and stock exhaust then you don't need to wire them open. If they do not open then you to fix the actuator or wire them open.
Old Dec 24, 2005 | 04:26 AM
rx7b13's Avatar
rb has a thick blockoff plate and i love it.
Old Dec 24, 2005 | 04:58 AM
Roll FIS green
well upon ripping apart my old motor... what im refering to as the sleeves are the metal tubes that you would insert the pineapple racing bits into... i was wondering if i pull THOSE out, or leave them in. If i leave them in, what position is open? Do I need to jb weld them to keep them from moving or something?
actually there is a place called metal depot right down the street... maybe i can start supplying these plates too for CHEAP... apparently 1/8" will work? i suppose it is not under enough vacuum to flex that...
Old Dec 24, 2005 | 04:59 AM
Roll FIS green
yes, it is an s4... and its a california motor, so i dont know about all the extra (if any) emmissions crap.
Old Dec 24, 2005 | 05:00 AM
Roll FIS green
and its an n/a... damn it
Old Dec 24, 2005 | 01:10 PM
Roll FIS green
go figure, yet another question answered by the FSM... kinda.
now i know that i CAN leave it in. but whats the fun in not messing with **** thats working?
can i pull those tubes out? is it more trouble than its worth?
Old Dec 24, 2005 | 01:16 PM
rick_tj's Avatar
You will lose a lot of your bottom end if you take the sleeves out. Remember, they stay closed until about 3800 rpm to keep enough pressure in the housings to make power down low, and then open when extra air is needed to lean out the fuel mixture some. You can take them out, and clean them up, but I'd recommend you put them back in. Remember though, the entire intake manifold assembly has to come off to get to the sleeves.
Old Dec 24, 2005 | 01:24 PM
Roll FIS green
believe me, im NOT trying to start another fight about drivability... the actuators are frozen, and i have absolutely no interest in fixing them. i was just wondering if there were any problems with taking the sleeves (?) completely out. the only reason i can think to keep them in is to ONE DAY... if ever, fix it, or rig it with an alternative pump/motor/whatever is around at the time. thanks though!
Old Dec 24, 2005 | 01:59 PM
Fire85GSLSE's Avatar
Chad Carson
My acv is removed and blocked off. I kept my 5 and 6 port in and use my header to open and close them when needed. That is an option if you want the best of low and high.
As for making block off plates, I would say no and buy these. I just ordered a set and man are they sweet and thick! Also a very good price. Check it out
http://www.2751engineering.com/2751parts.html
BLK 93
11
Sep 9, 2015 10:56 AM
risingsunroof82
Sep 7, 2015 01:11 PM
