how much power can the auto na diff take
Old Dec 23, 2005 | 03:31 PM
NashMan's Avatar
well i was woundering how much this diff can take
my plans were to weld it and that should make the diff strounger but don't really knwo have not look at the diff yet
ps how does welded diff feel liek wheil drive i have good idea what ti will be like thou but tell me what you think
oh yea plz don't flame me i have 350 ina rx7 that why i am askign these qestion's
oh i herd they did make 3.9 lsd one but only in japan ect or some thing
i need the diff to be as short as possilbe aka low geared
oh yae i have a 87 mazda rx7 gx
Old Dec 23, 2005 | 04:40 PM
NashMan's Avatar
bump no one knows geez can it at lest handle a t2 motor
Old Dec 23, 2005 | 05:11 PM
Speculum's Avatar
I'm sure this will be up debate, but yes I have run a T2 motor on a NA rear ... It held-up fine, however no drag-launches etc ... I have also run a welded diff for drag, however you will not be able to turn very well. Tire squeal and hop on any turn more than 20 degrees or so.
Old Dec 23, 2005 | 05:49 PM
Alex6969's Avatar
The Silver Bullet
if your looking for launches get a diff with a 4.3 ratio i belive the 88 GTU came with it. I'm not quite sure though. I'm still doing resarch for my Miata gear trans and rearend.
Old Dec 23, 2005 | 06:38 PM
NashMan's Avatar
that is way to much for my car 4.30 whould just be nut's
but wounder if the none lsd can take that alomt of power
is there any other diff i can use better then 3.9 hope fully
is there any ring and pions avlible for the t2 diff
Old Dec 23, 2005 | 08:53 PM
socalrotor's Avatar
auto's came with 3.90 sticks with 4.11. GTUs came with 4.30. Find a auto GXL s4 . It has a 3.90 LSD you want.BTW. Clutch type lsd in s4 gear type in s5
Old Dec 24, 2005 | 04:26 AM
NashMan's Avatar
sweet they make this diff but i bet it is hard as hell to find glx s4 eh
the s5 is 91 area corret me if i am wroung and the s4 are the 87 area
Old Dec 24, 2005 | 04:37 AM
Project84's Avatar
Open up! Search Warrant!
86-88 are S4
89-92 are S5
There is a FAQ at the top of the second gen page that should show you what each model came with, but the auto tranny cars had 3.90 rears, the 5spd cars had 4.11 and the GTUs cars had 4.3 rears. Note that there is a difference between the GTU and the GTUs model. The lower case "s" designates a different model then the GTU, it doesn't mean "plural" like you normally see in the english language.
Old Dec 24, 2005 | 05:02 AM
NashMan's Avatar
so is it hard to find gxl auto
cause that is what i am after now
should just bolt into the gx
Old Dec 24, 2005 | 05:12 AM
slpin's Avatar
7th Heaven
i think the diff oculd hangle quite a bit of power...
i was running a 11 seconds setup on that diff and its still fine
just dont wheelhop it.
streetlegal?
Mar 17, 2022 02:46 PM
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
