Megasquirt Nearly done my MS1 v3, what should be done?
Old Dec 22, 2005 | 01:15 AM
KamakazieX's Avatar
I've got a couple things to solder on, id say about 10, and the led's.. Anything i should swap out resistor/cap wise; eg. replace R41 with 10kohm 1/4watt..
Wondering if someone can break it down to specs.
I'm also going to try and fit that crank sensor circuit in the MS, just need to find a way to make room.
Old Dec 22, 2005 | 09:01 AM
muythaibxr's Avatar
MegaSquirt Mod
The FAQ contains all mods you need to do to the board to use it to control stock ignition, etc... on the MS.
bobybeach
Megasquirt Forum
Mar 5, 2009 03:24 PM
quasar
Megasquirt Forum
Dec 28, 2007 10:46 AM
fstrnyou
Megasquirt Forum
Oct 26, 2006 06:18 PM
fstrnyou
Megasquirt Forum
11
Oct 15, 2006 10:51 AM
SPERRYsan
Megasquirt Forum
Jul 15, 2006 07:00 PM
