Sponsored by: CARiD
White smoke when its cold
Old Dec 21, 2005 | 03:48 PM
floman's Avatar
When i start my rx7 in the morning to go to work, there is some white smoke coming from the exhaust. Its not alot but its enough to get me worried. I had an engine rebuild about 25000-30000 miles ago. I was wondering what this was caused by exactly and how can i fix it. Thanks
-Floman
Old Dec 21, 2005 | 03:51 PM
rotary2nr1's Avatar
can i torque it
cause in the winter u can see the smoke come out of the exhaust
Old Dec 21, 2005 | 04:02 PM
floman's Avatar
well i hope that was a serious post
Old Dec 21, 2005 | 06:56 PM
If it has a sweet anti-freeze smell then your engine is cooked. Blew a seal. If it doesn't smell and goes away quick and engine starts ok then its probably condensation in the exhaust. If you suspect the worst then have a mechanic stick an exhaust gas probe in the coolant. If there is exhaust gases detected in the coolant then a seal is blown.
If you only have 30k on the engine and never ever overheated it then it's probably just condensation. Good luck!
Old Dec 22, 2005 | 03:22 AM
floman's Avatar
thanks for the help. I hope is just condensation.
Old Dec 23, 2005 | 01:22 PM
mazdaspeed87's Avatar
lol dont worrie about it mine does it to its just because its damb cold out its as simple as your breath doing the same thing
Old Dec 23, 2005 | 01:23 PM
if its white be happy blue/black now you can worrie
Old Dec 23, 2005 | 04:15 PM
floman's Avatar
Well it had me scared for a while. Thanks
Old Dec 23, 2005 | 04:25 PM
floman's Avatar
well I am in Austin tx and it was 70 degrees out today but oh well.
Old Dec 24, 2005 | 02:51 PM
boost-in-rx7s93's Avatar
ok if it is white smoke on even a warm morning you probly have a blown coolant seal.
all rx7s ten to have there own degree of smoking, expecialy if it is cold. dont confuse condensation for smoke, to tell the defference smel for slight sweet smell as stated above!
thanks and good luck, joe
Bauer778
Nov 4, 2015 04:42 PM
mikedscpt
22
Oct 28, 2015 03:04 PM
qqqqball
11
Oct 9, 2015 07:06 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
