Glass moon roof
Old Jan 29, 2002 | 08:48 AM
lindr6's Avatar
Unhappy Glass moon roof
Somehow, one of the metal peices that the front clip thingies screw into which hold the clips onto the class has fallen off (I guess I was going to fast). Anyways, where can I get one of these peices at? Does anybody here have one I can have?
Thanks,
lindr6
Old Jan 29, 2002 | 09:45 AM
error402's Avatar
#!/sup_mod/üb3rg33k
You might be able to find one from a junk yard. Usally, if it a small piece they won't charge you a thing.
Old Jan 29, 2002 | 09:46 AM
JoshP's Avatar
Thumbs down hmmm
you're prolly better off my looking for another moonroof from a junkyard or sumthing. but if anything go to www.mazdtrix.com
they'd be the best bet.
Josh
Old Jan 29, 2002 | 10:15 AM
MIKE-P-29's Avatar
I beleive the clips that hold the roof in are the same as the metal counterpart, its the carraige bolt looking thingy that will be hard to find.
If its a 79 I got a glass roof for it for sale...
Old Jan 29, 2002 | 11:08 AM
lindr6's Avatar
Unfortunatly, it is that carrage bolt looking thing that I am missing. So you guys think that my best bet is junkyards?
Old Jan 29, 2002 | 01:20 PM
Seniorchief's Avatar
seniorchief
Veteran: Navy
Lightbulb
Victoria British carries all the hardware for Sun/Moon roofs. You can order a catalog by logging on to (www.victoriabritish.com)
Old Jan 29, 2002 | 01:59 PM
How in the hell do you lose the hardware that holds the moonroof on
the car,,while it's on the car ?? both kinds of roofs use the same
bracket on the front,that slip in one of the two attaching points.the
metal use screws,while the glass roofs use bolts that go all the way through the glass,,local hardware store has carraige bolts,use a carraige
bolt,put some silicon on both sides of the hole(s)then put the bolt through
the glass,the silicon acts as a buffer for the metal bolt to the glass,and
weather proofs as well,,i'd say use a nylock nut,,any threads showing
after the nut should be trimmed,so roof will close all the way down
Coochas
44
Nov 5, 2019 11:08 PM
Coochas
Oct 3, 2015 04:49 AM
