Apexi S-AFC, HKS AFR, or AIC?
Old Jan 28, 2002 | 06:11 PM
Drakk0r's Avatar
Which is better for street fuel tuning (using A/F ratio and EGT guages to tune), with larger than stock injectors and better fuel pump? The Apexi S-AFC, HKS AFR, or an Additional Injector Controller?
Old Jan 28, 2002 | 06:47 PM
CNYRX7tech's Avatar
Thumbs up Works for me
The Apexi' S-AFC has work well for me.
Old Jan 28, 2002 | 06:56 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Apexi S-AFC, HKS AFR, or AIC?
None of them should be tuned with using A/F ratio and EGT guages! I know people will disagree, but these devices are supposed to be used to acurately tune the fuel flow to the engines requirements. The best way to do this is on a dyno with a wide-band O2 sensor. You'll maximise power while ensuring no lean-outs. An hour on a dyno is a whole lot cheaper than a rebuild.
BTW, the AIC controls additional injectors (hence the name!), not the ECU controlled ones.
Old Jan 28, 2002 | 08:37 PM
rx7_turbo2's Avatar
Professor D.P
Is a dyno the best way to tune the S-AFC? Sure it is, but a A/F gauge and an egt gauge can do a sufficient job, untill such time as a dyno run becomes a reality.
ls1swap
Jun 3, 2024 03:25 PM
