are the toe links for passenger and driver side the same?
Old Jan 28, 2002 | 05:20 PM
KZ1's Avatar
KZ1
the rod on one of mine is bent, doesn;t look like it is damaged, but I have never sen that before. Had the alignement done, they said eveything is okay, but that is is bent. I am talking about the front passenger.
Old Jan 28, 2002 | 05:33 PM
nrolfes1's Avatar
are you talking about the anti-roll bar links? They are marked with L and R so I think they are mirror images of each other, not identical. They are common fail parts, mazdatrix has replacement ones that are better and cheaper than the stock ones.
Old Jan 29, 2002 | 08:30 AM
KZ1's Avatar
KZ1
nope, not the sawy bar links, but hte ones to adjust the toe.
Old Jan 29, 2002 | 07:33 PM
FD Racer's Avatar
sold the FD...kept the FB
You mean the rod on the steering rack?
Old Jan 29, 2002 | 08:01 PM
GsrSol's Avatar
Z06 powered FD
There isn't anything like that on the front. The only adjustment should be for the steering rack, the tie end rods are probably what you're talking about and they should be fine if the alignment is good.
Old Jan 29, 2002 | 11:05 PM
KZ1's Avatar
KZ1
yes, the stering rack rods with adjustments on them. Are they the same?
Old Jan 30, 2002 | 10:37 AM
Flybye's Avatar
It's never fast enough...
I removed my driver's side tie rod end last night because it was leaking. I orderd one today. I remember your thread, and I then asked if the part number for the passenger side is the same. Sure enough, both part numbers are the same. At least for an FD it is. The parts guy told me they are different for some cars.
Old Jan 30, 2002 | 10:53 AM
Flybye's Avatar
By the way, in case you were curious, the REAL Toe Links ARE the same
RaY358
Aug 19, 2015 11:44 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
