ignition
Old Jan 27, 2002 | 05:51 PM
Tom93R1's Avatar
gross polluter
ignition
I have a REPU that I put a 13b from an '86 RX7 into. Currently it is running an electronic ignition from about an '84 RX7 with a 12a. For the most part it seems ok but there are a few things that just don't work right like the vaccuum advance. I was wondering how much work it would be to pull the ignition system from a 2nd gen and use that in the REPU. Does the ignition system require the ECU? Or would it be no more than pull the sensor from the front cover, and get the coils? I haven't had time to get to the wrecking yard to look myself, maybe next weekend.
thanks.
Old Jan 27, 2002 | 09:10 PM
repuguru's Avatar
Thats a good question I am wondering right know. I want a good direct fire system also.
Old Jan 29, 2002 | 08:45 AM
Jeff20B's Avatar
Lapping = Fapping
I'm partial to DLIDFIS myself
Old Jan 29, 2002 | 09:24 AM
Tom93R1's Avatar
gross polluter
DLIDFIS?
Old Jan 29, 2002 | 09:56 AM
Jeff20B's Avatar
Lapping = Fapping
Yeah. I wrote a little article about how to hook it up here.
Old Jan 29, 2002 | 05:59 PM
Tom93R1's Avatar
gross polluter
Hey, that looks quite easy. Maybe an hour or 2 job? I have that Uncle Buck backfiring problem that you mentioned, it goes away if the timing is advanced but then preignition is a bad thing. I think I will make a trip to the junk yard and try the DLIDFIS and see if that cures the backfiring for me. I think I will bookmark that page so I can find it when I get my REPU back in Feb.
thanks
Old Jan 30, 2002 | 07:45 AM
Jeff20B's Avatar
Lapping = Fapping
Cool! Do you have an internal regulated alt? I got mine from an '81 or '82 RX-7. It fits good and is rated at 50 amps. It works perfectly with the REPU's stock 50 amp fusible link. It allowed me to remove my voltage regulator (as mentioned in the article).
My reason for asking is because I read something somewhere which said it is a good idea to switch to a newer alt when installing electronic ignition. I've seen it done both ways, but the RX-7 alt always works better.
Old Jan 30, 2002 | 09:33 AM
Tom93R1's Avatar
gross polluter
Hmm, I really don't know for certain which alternator is in there. When I bought the REPU it had a dead 12a in it, I assumed it came from an rx7 but I really don't know for sure. I will have to check that out. It looks really old though so I will probably end up replacing it just as a precaution. I will put in an rx7 alt because that does make sense. I won't have my REPU back until Feb 25 so no way to check yet
Old Jan 31, 2002 | 02:55 AM
NZGTrota's Avatar
hi im new to the forum i have built a 1983 rear wheel drive toyota starlet runing a 13b bridge port rotory engine , my problem is i have a carby set up and a 2gen s4 electronic distributor now do these dizzys have a built in ignitor pack or do i have to run 2 seperate ignitors,if anyone can help me even with another way of wiring it up please help thanks
Old Jan 31, 2002 | 08:53 AM
Tom93R1's Avatar
gross polluter
Currently in my REPU I have a 13b but I am using the electronic distributor from an '84 rx7 12a. I don't know about your ignition setup but the 1st gen ignition setup has the ignitors attached to the distributor. It is a very simple ignition to use. Just grab a dizzy. and 2 coils. run some wire and it is done. I am going to try our the DLIDFIS that 20B posted a link to, it sounds like a great system.
Old Feb 2, 2002 | 05:31 AM
NZGTrota's Avatar
kool thanks for the advice i am now trying to find a dizzy like yours! you said the ignitors are built in so do i just run a + and - from the coil or what, how exactly did you wirer yours up I know i seem slow on the electrical but i dont like it much so any help will be gladly accepted thanks
Old Feb 2, 2002 | 08:50 AM
Jeff20B's Avatar
Lapping = Fapping
http://www.geocities.com/cd23c/
I haven't posted any pics of any installations yet, but there is a basic wiring diagram at the top of the page on the DLIDIFIS link.
Old Feb 2, 2002 | 05:12 PM
NZGTrota's Avatar
cool ill go and have a look thanks heaps to you guys for helping me, my project is just about finshed now so i can go crusining
Old Feb 20, 2002 | 02:11 AM
NZGTrota's Avatar
i got one of those 12a dizzys with the built in ignitors, now sounding dumb but can anyone tell me on the ignitors which one is the (+) and which one is the (-)?????? or doesnt it matter? also does anyone have any photos of this system set up,
WANKfactor
Sep 29, 2015 01:14 PM
GKW
Sep 28, 2015 04:34 PM
subeone
Sep 24, 2015 09:58 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
