TO4S Single Turbo
Old Dec 2, 2005 | 03:09 PM
z28_SS's Avatar
--Almost Retired--
TO4S Single Turbo
I was wandering anybody running this turbo on here? How reliable and strong this turbo is. What are the opinion?
Old Dec 2, 2005 | 03:47 PM
Bacon's Avatar
IRS 4 Life
love it,runs out of steam north of 22psi, 10 lbs @ like 3600 rpm, make sure you have a good manifold, my #'s are with a OBX manifold
Old Dec 2, 2005 | 05:04 PM
z28_SS's Avatar
--Almost Retired--
I see your 1/4 mile run. That low 12s you did is on 22 PSI.? Shouldnt' it be a better time.
Old Dec 2, 2005 | 05:29 PM
Wargasm's Avatar
Weird Cat Man
Probably one of the very best street turbos for an FD. I can make 15 PSI by 3500-3600 rpm... 406 rwhp at 14 PSI... It rocks... If you're looking for a street turbo, excellent choice. If you want a pure drag turbo, you probably want something bigger.
http://dyno.zeroglabs.com/
Old Dec 2, 2005 | 05:38 PM
z28_SS's Avatar
--Almost Retired--
Thanks Wargasm. Mid to high 11's is good. Any better time for the TO4S? Or is that the best it can do. 12s.
Old Dec 2, 2005 | 05:48 PM
Kahren's Avatar
i am not a girl
400+ whp in an fd should do 10s if u can drive. t04s can do that no problem.
Old Dec 2, 2005 | 09:04 PM
rx7will's Avatar
Are you guys talking about the hks to4s or the turbonetics tso4. I was told very good things about the hks to4s. The hks tubo is $2800, thats too much for what i want out of the turbo.
Old Dec 2, 2005 | 09:33 PM
Kahren's Avatar
i am not a girl
hks uses garett turbines and modifies them to flow to their liking, atelst what i heard. both the turbonetics and the hks ones will produce this power. 2800 is the turbo kit not just the turbine, i think he was talking about the turbine itself?
Old Dec 3, 2005 | 08:06 AM
Bacon's Avatar
IRS 4 Life
As some one mentioned the turbo is good to get into the mid/high 10's. This turbo is great compromise between lag and power. As you can see on that time slip, aside from sleeping @ the light I could have ran a quicker 60' time. On that run I spun them through first, all of 2nd, and part of third. The thing in that run you should be looking @ is MPH, which is a better representation of power. ET will vary on more factors.
Hell I ran a 12.4 @ 95mph on this setup. But since that run was on slicks I had a 1.5 60' time and hooked like crazy in 1, 2, and 3rd. then almost put it in the wall so I lifted. ET has a lot to do with driver error.
Also not my Afr’s are lover 11’s on C16, I’ve been having shaky boost readings from not having any sort of damper for the Map sensor. So there’s still power left to be had..
Ohh boost comes on so fast I am probably wrong on my readings, also I found out how inaccurate my crap-o-meter gauge is. Ill have to do some testing with my defi gauge.
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
