Anyone rebuild wiper switch?
Old Jan 26, 2002 | 10:44 PM
t_mak@mail.plymouth.edu's Avatar
Hey guys, anyone rebuild wiper switch here? I think mine is on its way south. The rear wiper dont want to park at its "home" sometimes
Old Jan 26, 2002 | 11:45 PM
FEDREX's Avatar
"Just Looking".......
www.fc3s.org/wiper.html
Old Jan 27, 2002 | 12:27 AM
mazdaspeed7's Avatar
mad scientist
Ive done it 4 times between 2 cars. Piece of cake.
Old Jan 27, 2002 | 08:23 AM
I suck at soldering....
Old Jan 27, 2002 | 09:50 AM
HAILERS's Avatar
HAILERS
MAZDASPEED7......I have two switches apart with both relays out. The problem is.....I read a previous post that gave the OMRON relay parts that needed to be ordered. Well I happen to have a OMRON catalog, current, only three months old, and although they do have a G5LE-14-DC12 but do not reflect the other relay whos number escaped me right now. The one above is the big one. I need the source for the little one and a part number. So I'm asking, what numbers do you order by and or do you have some that you'd be willing to sell at a profit??????????????
Old Jan 27, 2002 | 12:33 PM
mad scientist
Actually, I just pulled the old relays apart, and cleaned the contacts. If you want the part# on the relay, Ill see if it is still on the relay. Could you take a pic of exactly which one youre looking for though?
Old Jan 27, 2002 | 02:30 PM
HAILERS's Avatar
HAILERS
NO, I can read the OMRON number on the relays. They're just not in the DigiKey catalog. Someone posted the alternate part numbers, but only one was in the catalog. And there was another post that they'd called Digikey and they did not have the numbers refered to on the other post. I guess I can look at this Digikey catalog and find one that is close to the original. Thaks for replying though. I've soldered just about everything on this buggy, but I've been in the process of fixing the wiper switch for the last three years. Once I just put in a sw that was tied into the sw, that when switched would put a ground on the wiper motor and put it in the high speed range. Two sw to do the job of one. Thanks again.
Old Jan 27, 2002 | 02:39 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
My car is totaled Ill sell you mine Rotary performance did mine.
pc2@mindless.com
Under PSI
19
Sep 23, 2015 11:47 PM
rotor_veux
Sep 3, 2015 07:10 PM
