p.s.,smog pump,ac,and egr valve removal
Old Jan 26, 2002 | 09:45 PM
TEDMAN's Avatar
Can l just remove all the power steering parts or do l need to replace the rack with one from a non p.s? car. If not how hard will it be to steer? As far as the smog pump goes do l just remove it and cap off where the hoses go? Im going to remove the a.c. too so dose that mean that l will just use 1 V-belt to run crank,wp,and alt? Im trying to clear the clutter under the hood is their anything else l can get rid of? Thanks for all the help,TEDMAN
Old Jan 26, 2002 | 10:44 PM
InfiniIIIREX's Avatar
The removed Power steering doesn't take long to get used to but it gives your arms a workout if your trying to parallel park or something. Remove the whole big airbox assembly and you will have a lot of room. While your at it get a better air filter.
Old Jan 26, 2002 | 10:52 PM
TEDMAN's Avatar
p.s. removal
Thanks for the info. How come my smog pump says DO NOT REMOVE NO OILING should l put it back on? Thanks
Old Jan 26, 2002 | 11:52 PM
tIIforever's Avatar
terminally boosted
if the smog pump is the one that goes into the cat then it says that because your cats will get fried.
Old Jan 27, 2002 | 12:25 AM
4rxz's Avatar
do not remove the smog pump
if you fry your cat you can kiss your engine good-bye
get a staight pipe first a muffler shop can make one 2.5" removable
or a racing beat presilencer and downpipe
buy a Air Control and Check Valve Cover Plate to remove the accv
wire open your ports 5 & 6 (racing beat)
removing the sleeves is even better
remove the air pump
rest
zoom
if you remove the ps change the streering rack to manual
i have both manual and ***. ps that is taped out
the manual is a lot easier to drive
Old Jan 27, 2002 | 12:36 AM
4rxz's Avatar
s
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
