Generation II Copper Header Wrap
Old Nov 29, 2005 | 12:38 PM
rotarypower101's Avatar
sdrawkcab
Has anyone tried the GENERATION II COPPER HEADER WRAP from thermotec?
http://thermotec.com/products/full/11031/11031.html
Wondering if is as flexible as the fiber wrap, and if any noticeable difference in radiant heat between standard glass and this newer stuff was present? Because it looks pretty stiff from the pics.
Also wondering if anyone has any theory as to why it (I can only assume) has copper in it? Seems counterintuitive to me at the moment?
Has anyone taken a temperature of the external surface of the down pipe with their temp gun they could share?
Anyone have any updates on using the std. Glass stuff?
No one is having a problem using the lower temperature rated brands ~1250- over the thermotecs 2000F rating?
http://store.summitracing.com/defaul...7&autoview=sku
Decent threads on the subject, but not on the differences..
https://www.rx7club.com/showthread.p...t=exhaust+wrap
Old Nov 29, 2005 | 02:34 PM
NewbernD's Avatar
Tequila? ..it's like beer
I use the traditional glass thermo-tec wrap on my downpipe and it seems to hold up fine. I imagine the exhaust manifold might be more demanding with temps, butfolks have used it here too, with success.
As to why copper, I can only guess that if you have something expelling in the neighborhood of 2000° you might not be able to "block" all of that heat with fiberglass and might need to conduct a little bit away through the copper.. I'm sure that's complete BS though.. just running my mouth.
Old Dec 2, 2005 | 09:13 PM
rx7will's Avatar
I orderd it from summit but i returned it because i bought a down pipe that was alread wrapped. It looked like the regular wrap with bits of copper in it.
Coochas
44
Nov 5, 2019 11:08 PM
Andrew7dg
Aug 6, 2017 01:41 PM
