First Dyno Run
Old Nov 26, 2005 | 09:23 PM
Cough XAS
First Dyno Run
I'm really happy with my horsepower, though i'd like to see the torque a bit higher. My car currently is running stock ports, R-tek 1.5 chipped ecu, and it hasnt been tuned yet.
The psi i was pushing was 17 pounds.
300hp is pretty much maxed out with my fuel mods. If i want to go any higher ill have to get some bigger injectors and a standalone.
Old Nov 26, 2005 | 09:24 PM
Cough XAS
Here is my engine bay
Old Nov 26, 2005 | 09:33 PM
Rotortuner's Avatar
Undercover
Not bad numbers for the stock ports. I would be very careful with those AFR's. Those dont look good at anything above 5k rpm. You better get some more fuel or it wont last long...
CJG
Old Nov 26, 2005 | 09:36 PM
Cough XAS
I'll go ahead tonight and mess with the safc. I currently have stock primaries and 720cc secondaries with a walbro 255. Those mods are pretty much maxed out for 300hp. I'll need to go bigger on the secondaries.
Old Nov 26, 2005 | 11:00 PM
Rotortuner's Avatar
Undercover
Ya, if i was you id throw a set of 1000's in there. that may help with your lean condition at 5k. I would just be cautious when driving that and boosting it. just keep the boost down until you get some bigger injectors. with the amount of money you have just stuck into it, it would stuck to blow a seal. Get a microtech!!
CJG
Old Nov 27, 2005 | 12:54 AM
13bpower's Avatar
s4 for life
Yikes, good power numbers, but please for the love of happy apex seals get some more fuel in there.
Old Nov 27, 2005 | 03:27 AM
Cough XAS
Whats nice is that bigger injectors are pretty cheap, plus i already have an aftermarket 2ndary fuel rail. I'll just need some fittings.
Old Nov 27, 2005 | 04:59 AM
88t2romad's Avatar
(_8(|)
1600's only 89 bucks.....now only if mine would hurry up and arrive.
1000's are 99 buckaroos.
Where did you dyno at? Tacoma?
Also, is it possible to change the position of your AFM? Seems kinda like that position would be hindering the flapper from opening properly
Old Nov 27, 2005 | 11:08 AM
KompressorLOgic's Avatar
I
nice dyno! but that is a dangerous AF ratio!!! your walking a thin line! at least get that down to the low 12's for A/F
Old Nov 27, 2005 | 02:03 PM
woundup7's Avatar
The Outsider
Pretty impressive Wally, are you running a stage 2 or 3 BNR. Danger Danger on the afr, in case no one mentioned that.
Intec racing in Kent.? I going to be buying a wide band setup pretty quick, let me know if you have any info or want any info on one.
Boost Safely!
Old Nov 27, 2005 | 02:12 PM
rotariesRmonsters's Avatar
very nice numbers gud luck
Old Nov 27, 2005 | 03:00 PM
notveryhappyjack's Avatar
1 bar boost
Yes Intec Racing is in Kent, they had an open dyno day this weekend.
Old Nov 27, 2005 | 04:11 PM
Cough XAS
Yep it was at Intec Racing in Kent. Oh and it is a stage 3 bnr.
I richend 5k and above about 10 to 15% on the safc, just to be safer.
Old Nov 27, 2005 | 07:01 PM
turbo-polak's Avatar
id like more info on that v-mount setup!
nice #'s!
Old Nov 27, 2005 | 07:16 PM
Icemastr's Avatar
All Motor
No you don't.
Old Nov 27, 2005 | 09:49 PM
Originally Posted by Icemastr
No you don't.
huh?
or maybe you're expecting an "eh?" because im canadian
Old Nov 27, 2005 | 11:16 PM
z-beater's Avatar
REW'd FB
^^^lol agreed. Nice numbers Wally. I knew that beast had a little punch behind her. What are your plans for fuel pump?
Old Nov 28, 2005 | 12:59 AM
Cough XAS
I might just keep the same fuel pump. What i do need is an fpr though. I'll be looking into a pair of 1000cc for my secondaries soon.
Once i get more money it's standalone time.
Old Nov 28, 2005 | 01:16 AM
kettlman's Avatar
THE ONE. THE ONLY!
well, why didn't anybody share the info on the dyno day? i'm dying to hit mine up now.
Old Nov 28, 2005 | 02:32 AM
dr.jones63's Avatar
It's a Hammer
Very impressive!!!!!!!!!!!!!!!!
I would spend the $25 and upgrade to 1.7
Do you have a wideband? If you don't you need one. Its amazing how easy it is to get HP out of a T2.
Old Nov 28, 2005 | 12:27 PM
Rotortuner's Avatar
Undercover
Befor i bought mine, the previouse owner dynoed it at 332 RWHP.
S5
720 primaries
1250 secondaries
this turbo (i sold it to him):
https://www.rx7club.com/single-turbo-rx-7s-23/help-me-name-turbo-476397/
Stock top mount IC
80, DP and exhaust
greddy Super AFR controller.
walbro 255
Now its time to go bigger...
Old Nov 28, 2005 | 03:26 PM
Cough XAS
I need a wideband. I tried messing with the safc by looking at my o2 on the dyno sheet. I also figured out my boost controller so it doesnt overboost now. On hi i hit 15psi and it stays.
Old Nov 28, 2005 | 09:04 PM
pp13bnos's Avatar
Pineapple Racer
I would'nt be boosting at all, until you get the fuel system and the car tuned. You're playing with fire, and I'll bet you $$ the car will last less than a month. I'm not trying to be a jerk, but its just plain stupidity to be running a car that lean....even if you did turn the boost down to 15lbs. CJ
Old Nov 28, 2005 | 09:48 PM
Rotortuner's Avatar
Undercover
Ya, SAFC IMO is junk. I had a friend that used one a couple years ago and he went through 4 engines in one year. He basically had the same setup you did, and it was the most unreliable car. I would run stock boost for now, by a $700 microtech and grab some 720 primaries and 1600 secondaries and a FPR then you can run 15-17 safely.
CJG
Old Nov 28, 2005 | 11:50 PM
Cough XAS
ok, ill be turning my boost down then. I figured out my boost controller so it wont overboost again.
