Hot housing A/R upgrade question
Old Nov 25, 2005 | 08:07 PM
Jack's Avatar
I am currently running a T04E 57 trim .84 a/r (divided) p wheel. My question what power/back pressure upgrade would achieved by upgrading the hot housing to a 1.00a/r (divided).
Old Nov 26, 2005 | 02:29 AM
RETed's Avatar
Exhaust backpressure should go down.
Power band shifts higher in the RPM band.
-Ted
Old Nov 26, 2005 | 06:20 AM
Jack's Avatar
-Ted
Ted
Is this upgrade worth it? the motor has stock ports and I run a high flow cat? Or a better question, what hot side a/r is best balanced for a street/track car at 13psi with the aforementioned turbo.
Old Nov 26, 2005 | 02:50 PM
MrDirt's Avatar
Originally Posted by Jack
Ted
This is all completely dependent on where you want your powerband. If you enjoy having a little quicker spool, then you might want to retain your current housing. If you want to push some bigger numbers, but are willing to live with a little more lag, then try out the 1.00.
Old Nov 26, 2005 | 08:35 PM
RETed's Avatar
Are you running a divided turbo exhaust manifold?
If so, the 1.00 should be fine.
How quick does the 0.84 spool now?
The T04E "57" is a bit small for a 13B, IMO, so it should still spool rather quick even stepping up one size on the turbine A/R.
-Ted
Old Nov 27, 2005 | 08:24 AM
Jack's Avatar
-Ted
Yes the exhaust manifold id divided, and does spool quickly with the .84. Why do you feel the "57" is sized small, my target power was 350hp @13psi. What turbo's would you feel would be more efficent for those hp parameters.
Old Nov 28, 2005 | 06:44 AM
RETed's Avatar
If I remember correctly, the "57" top efficiency is about 300hp @ 15psi.
I would step up to at least the "60" trim, as that should get your power goals.
...unless we're talking BHP at the flywheel?
My numbers are at the rear wheels on a DynoJet.
-Ted
Old Nov 28, 2005 | 08:55 AM
Jack's Avatar
-Ted
Per the Turbonetics Compressor maps, "57 Trim" is good for 49 lbs/min, "60 Trim" 50 lbs/min. I am not sure the upgrade would be worth it unless I upgraded the hotside to 1.00 ar
Old Nov 28, 2005 | 09:07 AM
RETed's Avatar
Yes, those are maximum flow numbers...
So they would be applicable if you're running...about 30psi?
T04E "57"
T04E "60"
-Ted
Old Nov 28, 2005 | 11:22 AM
Jack's Avatar
T04E "57"
T04E "60"
-Ted
Are you implying, at lower boost levels, lets say a bar, the 60 trim flows much higher than the 57 trim?
Old Nov 28, 2005 | 03:59 PM
MrDirt's Avatar
That is the point of having a larger compressor.
Old Nov 28, 2005 | 10:04 PM
RETed's Avatar
Yes.
Look at where the middle of all the concentric rings fall...
On the "60", it right around 2.00 or about 15psi.
On the "57", it's slightly higher.
This is where the turbo is running at it's most efficient.
Now, go down vertical, and the "57" is pumping slightly under 30 lb/min, while the "60" is doing a solid 30 lb/min.
-Ted
Old Nov 29, 2005 | 07:54 AM
Jack's Avatar
Thanks Much !!
Old Nov 29, 2005 | 11:58 AM
floman's Avatar
My friend got 379 on pump gas at 1bar on that same turbo
Old Nov 29, 2005 | 09:52 PM
RETed's Avatar
57 or 60?
-Ted
Old Nov 29, 2005 | 10:25 PM
meddle's Avatar
57 or 60?
-Ted
I don't know, why don't you consult hitmans website then assert your internet dominance.
