which size secondaries should i go with?
Old Nov 22, 2005 | 02:44 AM
turbo-polak's Avatar
for 350whp with a hybrid....
id like to keep the 550cc primaries... what should i go with for secondaries?
i have a lead on a pair of 1600's, are they toooooo big for my application?
Old Nov 22, 2005 | 03:15 AM
bcty's Avatar
Boost This!
4 x 720 would be easy to tune
or just grab some 850's outta a 3rd gen
Old Nov 22, 2005 | 03:58 AM
RETed's Avatar
IMO, they can't support 350 at the wheels unless you start to bump up the fuel pressure.
Too bad they don't "drop into" a stock FC fuel rail.
-Ted
Old Nov 22, 2005 | 10:23 AM
cewrx7r1's Avatar
Eye In The Sky
550/1200 will work fine for 350RWHP and if you do some simple rewiring of the fuel pump it will support even closer to 390RWHP.
Old Nov 22, 2005 | 02:17 PM
FC3S.USD's Avatar
Where is my Life ?
.... double post
FC3S.USD's Avatar
Where is my Life ?
if your goinf to use the microtech you have in your sig, then 1600;s will work .
1200's would be ideal. But they most likely will cost more than the 1600's
Old Nov 26, 2005 | 05:24 PM
BLitzed33's Avatar
You can try the 1300 secondaries, that should be fine with a upgraded fuel pump
Old Nov 26, 2005 | 05:46 PM
yep, i have a walbro 255
Old Nov 26, 2005 | 05:53 PM
BLitzed33's Avatar
Cool, let us know how it goes
Old Nov 26, 2005 | 06:01 PM
oh for sure.
Old Dec 3, 2005 | 07:43 PM
1300's from where?
ive looked at some online injector stores... 1600's seem to go for around $100 a piece...
i want the powerband to be smooth (drift car) i need it to be smooth, and not a peak hp figure...(maybe i shouldnt be using a rotary )
4x850cc's or something along those lines will work fine, no?
what will the stock injectors at like 90% duty cycle support?
i wont jump to 350whp right away.
probably around 270-280. i'll be running 7-10psi with the my hybrid t4.
cheers,Dan.
Old Dec 3, 2005 | 08:55 PM
RETed's Avatar
Powerband has nothing to do with fuel injector size as long as the EMS can handle it.
Oh wait, you're running a Microtech!
-Ted
Old Dec 3, 2005 | 11:17 PM
-Ted
well i guess what i was trying to say was.. i dont want a *blirp* as usually described by 1600cc secondary owners
Old Dec 4, 2005 | 01:07 AM
GregW's Avatar
~!@#$%^&*()_+
1600's are not bad once you figure out how to tune arround the boost transition.
Old Jan 3, 2006 | 12:45 AM
how would i get FD 850cc injectors to work with my t2?
Old Jan 3, 2006 | 02:54 AM
RETed's Avatar
You need a custom fuel rail for it.
FD's run all side-feed fuel injectors.
FC's run all top-feed fuel injectors.
They are basically not swappable.
-Ted
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
